2018 axle block pre-orders
3 Attachment(s)
We've been testing these quick adjust axle blocks that we built for the 2018-2019 EC, XC, and GP models and are taking pre-orders now. The bolts don't require a jam nut and the blocks are much more accurate then the cast OE blocks that touch just a corner of the adjuster bolt. We've also had many issues with the OE closed end axle nut splitting open when hitting trail objects hard enough.
The kit will include both axle blocks, adjuster bolts, and an open-end nylock nut. We'll be selling these for $90 and they are AMERICAN MADE! We're considering a drilled version of the left block as an option for an axle pull so please share any thoughts below or visit gasgaspartshouse.com to pre-order. Thanks! |
I take it that the adjuster block on the nut side, doesn't "fall out" when the axle is removed?
Correct, the nut side stays in place and the left side comes off with the axle when pulled.
Awesome.
Pencil me in for a set. |
My rear axle nut had a hairline crack in it.
Ordered this kit last week. Very well made and thought out. The axle block stays in the swing arm, not parts falling out. Makes tire changes fast. Highly recommended upgrade for your '18 on up bike. |
And just trying to order one to be shipped to Australia, and shipping cannot be calculated so I cannot checkout. Anyone able to assist?
I'm in Sunbury. |
Sweet as , Im in Altona.
If I'm motivated I'll fit tomorrow :D |
