Old 05-20-2024, 05:39 AM
Cox76y Cox76y is offline
Default Stator or CDI??
Hi all,
Just hoping someone can assist with an electrical issue I have. I have an 2018 ec300. Currently the bike seems to be running OK however, battery is not charging and the lights are not working. I think I may have an cdi issue from a previous mistake I made when I hooked up the battery incorrectly. I hooked positive n negative up incorrectly in the dark. I blew the rectifier./regulator and replaced that. I've checked resistance on every pin in the cdi and have an open circuit on 2 pins. Does anyone know if this is normal? Would it indicate a faulty ecu? Thanks
Old 05-20-2024, 05:31 PM
SS109 SS109 is offline
It's not the CDI as it has nothing to do with running the lights or charging the battery. Look at the factory wiring diagram and figure out if that open circuit belongs there or not. Is there fuse or fusible wire that you popped when hooking the battery up backwards?
stator Getoviq95 "Wanted to Buy" & "Want To Trade" 0 12-29-2016 06:51 AM
where to buy a new stator ec gasser Enduro Electrical & Wiring 0 04-05-2016 02:09 PM
Stator ref for MC or EC EC250 Enduro Electrical & Wiring 4 02-26-2016 10:20 PM
still looking for help on the stator KTMAndy Enduro Electrical & Wiring 9 01-02-2014 12:04 AM
2k3 stator with cdi from 2k2 whodat Enduro Electrical & Wiring 3 07-21-2013 10:34 AM
