Old 07-17-2008, 09:23 PM
Harry's Avatar
Harry Harry is offline
Default Fork Sub Tanks
Hi, I came across a thread regarding fitting of sub tanks to WP forks, can't for the kife of me find it again. Can anyone point me in the right direction??
Thanks
P.S I have tried to search for it.
Old 07-18-2008, 03:37 AM
mountain thumper's Avatar
mountain thumper mountain thumper is offline
ive notice the search isnt very smart. when i update the ims post, i cant search for ims, bigger tank, ims will, anything in the title. the only way i get back to it is by searching for all posts ive made, or actually going into the right section, i cannot get it with search.
Le Crutan
98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD)
FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck:
Old 07-19-2008, 08:44 AM
That was me. I designed and built a sub tank setup for my '03, and it went with the bike. Unfortunately it does not turn up in search, I will look into it. I liked it a lot on the WPs, thought it was a definate advantage. The Zokes are so much better with just minor valving changes that I wasn't as motivated to do it. Les built a set for his custom XR250 (with Zoke 45s) and said it helped a little but the forks worked great before the tanks. He thinks the WPs respond better due to the pressue ramping up faster.
Basically what a sub tank does is create a position AND speed sensitive air spring that works in parallel with the fork spring (with no tank you always have a position sensitive air spring). The idea is to move the progressive component (air spring) to a position later in the travel and at a higher fork speed by adding volume on the other side of a metering valve. This keeps the action on small stuff plush and retains bottoming resistance.
Old 07-21-2008, 07:04 PM
Harry's Avatar
Thumbs up
Thanks GMP, I would appreciate, if possible, any info on flow control valve and tank sizes etc.
I hate big fuel tanks...until now Keg Enduro Product Reviews 10 09-19-2010 03:09 AM
Safari fuel tanks gasgasman Enduro Product Announcements 17 02-21-2010 05:57 PM
sub tanks skid jackson Enduro Suspension 1 02-19-2007 08:14 PM
