Old 07-24-2022, 05:25 AM
Davehuge's Avatar
Davehuge Davehuge is offline
Default Triple Clamp Bolts Torque?
Hi all, I have a 2004 EC300 with Marzocchi forks.
Can anyone tell me the correct torque for the triple clamp bolts?
I'm confused as the Torque Table states 20Nm upper and 16Nm and lists them as M8 bolts, but mine has M7 bolts.
Old 07-24-2022, 09:08 AM
Anders Anders is online now
I think all years have M7 bolts. The torque you have found seem quite ok to me.
Old 07-24-2022, 12:11 PM
webmaster's Avatar
Administrator
For reference.
http://www.gasgasrider.org/torque_table.jpg
Jeff
Old 07-24-2022, 12:12 PM
Davehuge's Avatar
Hi Jeff, yes that's the Torque Table I was talking about. But it list the bolts as M8 and mine are M7.
Old 07-26-2022, 10:41 PM
webmaster's Avatar
Administrator
....it was put.together by Glenn quite a while ago. So the size of fasteners might have changed along the way. Not sure.
Jeff
Old 07-27-2022, 01:11 AM
SS109 SS109 is offline
I had an '05 with 45mm Marzocchi forks and used that torque guide on it. Seemed to work good for me.
White Power triple clamp torque specs??? motorhead Enduro Suspension 3 03-20-2019 04:44 PM
Scotts Triple Clamp Part # 6043-12 & steering stabilizer handlebar clamp jeffp Parts 0 12-31-2015 07:07 PM
Stuck triple clamp pinch bolts 400_racer Enduro Chassis & Body 9 08-12-2012 10:32 PM
Fork Clamp Pinch Bolts - Torque Specs JP4 Enduro Suspension 1 03-09-2012 02:03 PM
Torque Spec's Triple Clamp Pinch Bolts? ramcclure200 Enduro Suspension 6 02-20-2008 06:50 AM
