Old 12-09-2007, 05:45 PM
Brian VT Brian VT is offline
Question Stripped
Any thoughts on how to repair stripped threads near the bottom of my WP43 fork where the bolt that holds the fork guard on goes ? I thought about filling it with JB weld and re-tapping it but I couldn't find a bottom tap locally. You pros must have a better idea ?
Old 12-09-2007, 06:25 PM
Rick's Avatar
Rick Rick is offline
You might want to look for an incert / helicoil?
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 12-09-2007, 07:17 PM
First thing I'd try is the HTS2000 aluminum brazing rods, as I have them and they work great. Clean the hole, heat, and just partially fill the bad threads. Retap and your done. You'd have to disassemble the fork (cartridge) and most likely use a plumbers turbo torch or oxy gas torch due to the mass but the repair would be like new. JB Weld will work but has much less strength. mcmaster.com for options and any machine type tools you can't get locally.
Old 12-09-2007, 08:13 PM
Originally Posted by GMP View Post
First thing I'd try is the HTS2000 aluminum brazing rods...
Cool stuff ! I had never heard of it.
http://aluminumrepair.com/aluminum_repair.asp
Old 12-09-2007, 09:06 PM
This stuff is worth every penny in fixing sloppy shifters and brake pedals alone.
right side PV vent stripped....help joey11 Enduro Engine - 2 stroke 5 06-20-2009 02:38 PM
Stripped bottom of Ohlins prk03 Enduro Suspension 8 01-25-2009 09:03 PM
Stripped screw in gas tank prk03 General Discussions & Announcements 2 06-18-2008 11:19 AM
stripped hex head nhrider General Discussions & Announcements 11 05-28-2008 12:06 PM
