Old 10-18-2019, 01:11 AM
Default 2018 EC300 Front and Rear Stock settings
So seeing as everyone else is lazy and hasn't pulled their forks and shocks apart for my own curiosity I had to do it myself!
KYB Front forks
Compression base valve:
11x0.3 (3)
20x1.7 (base plate)
14x0.3 (6)
16x0.11
18x0.11
20x0.11
22x0.11
24x0.11
26x0.11
28x0.11
30x0.11
32x0.11
21x0.11
32x0.11 (11)
Piston
Check valve
Spring
Collar
Nut
Mid valve: Compression
Stepped washer
8x0.2
Collar
Spring
17x0.3
15x0.3
11x0.3
12x0.11
14x0.11
16x0.11
18x0.11
20x0.11 (4)
Piston (had the usual bleed hole forgot to measure it)
20x0.11 (3)
12x0.11
18x0.11
16x0.11
14x0.11
12x0.11
11x0.11
16x1.5 (base plate)
Nut
(Float was 0.7mm in the above stacks)
KYB Rear Shock:
Compression:
22x0.3
24x0.3
26x0.3
28x0.3
30x0.3
32x0.3
34x0.3
36x0.3
38x0.3
28x0.11
32x0.11
40x0.2 (10)
Rebound:
36x0.2 (7)
28x0.11
36x0.3
34x0.3
32x0.3
30x0.3
28x0.3
26x0.3
25x0.3
24x0.3
23x0.3
26x0.4
Hope this helps some one! I stiffened up the rebound damping on both the shock and forks and softened the compression in the base valve as I was most of the way out on the clickers and mostly in on the rebound. I added a 5.8kg/mm rear spring and some 0.46kg/mm springs up front. Not massive changes as it is pretty good out the box!
New settings:
KYB Front forks
11x0.3 (3)
20x1.7 (base plate)
14x0.3 (4) <removed 1
12x0.12 <added this
14x0.3 <moved here from above
16x0.11
18x0.11
20x0.11
22x0.11
24x0.11
26x0.11
28x0.11
30x0.11
32x0.11
21x0.11
32x0.11 (11)
Piston
Check valve
Spring
Collar
Nut
Stepped washer
8x0.2
Collar
Spring
17x0.3
15x0.3
11x0.3
12x0.11
14x0.11
16x0.11
18x0.11
20x0.11 (4)
20x0.11 (3)
14x0.11 <this replaced the 12x0.12
18x0.11
16x0.11
14x0.11
12x0.11
11x0.11
16x1.5 (base plate)
Nut
KYB Rear Shock:
Compression:
22x0.3
24x0.3
26x0.3
28x0.3
30x0.3
32x0.3
34x0.3
36x0.3
38x0.3
28x0.11
32x0.11
40x0.2 (10)
Rebound:
36x0.2 (7)
28x0.11
36x0.3
34x0.3
32x0.3
30x0.3
28x0.3
26x0.3
25x0.3
24x0.3
removed the 23x0.3 here
26x0.4
Old 10-18-2019, 04:07 AM
stabak's Avatar
stabak stabak is offline
Thanks Nate
EC250 2019
Old 10-18-2019, 09:25 AM
ECRider ECRider is offline
Good on ya Nate! I'm about to soften the stacks on both my forks and shock as i have the compression clickers a fair way out.
For my 92kg race weight I'm currently running 0.46 and 0.42 springs with 2.5 wt oil up front with a 5.6 shock spring. Rebound seems to be ok.
GG GP300 18
KTM 350EXC 17
GG EC 450, GG EC 250 08, KTM 525 EXC 06, KTM 400 EXC 01, XR400 97, VTR1000 98, VFR750 95, Husaberg FE400 96, RMX250 91, Maico 490 84, IT250J 81, RM250C2 79, Bultaco Alpina 250 77 - All sold
Old 10-18-2019, 09:18 PM
Motorman_55792 Motorman_55792 is offline
Thank you! I've been waiting for someone to do this! (Mine was already revalved when I bought it).
Old 10-29-2019, 09:06 PM
Went out for a little blat in the bush this morning at the local, new suspension feels sweet! I am riding a lot quicker but still maintaining the ability to punch over obstacles. It is a little harder to preload the front but it seems to just clip the rocks/logs and sail over. I was well worn out by the end of it though. Bit humid today. The fatty front barely hits the pipe guard now too, only slightly rubs on big drop offs. I would like a bit more rebound on the rear shock though. I?ll sort that out next service.
Old 03-25-2020, 07:34 PM
JoseGas25's Avatar
JoseGas25 JoseGas25 is offline
KYB Front forks
11x0.3 (3)
20x1.7 (base plate)
14x0.3 (6)
16x0.11
18x0.11
20x0.11
22x0.11
24x0.11
26x0.11
28x0.11
30x0.11
32x0.11
21x0.11
32x0.11 (11)
Piston
Check valve
Spring
Collar
Nut
Stepped washer
8x0.2
Collar
Spring
17x0.3
15x0.3
11x0.3
12x0.11
14x0.11
16x0.11
18x0.11
20x0.11 (4)
20x0.11 (3)
12x0.11
18x0.11
16x0.11
14x0.11
12x0.11
11x0.11
16x1.5 (base plate)
Nut
KYB Rear Shock:
Compression:
22x0.3
24x0.3
26x0.3
28x0.3
30x0.3
32x0.3
34x0.3
36x0.3
38x0.3
28x0.11
32x0.11
40x0.2 (10)
Rebound:
36x0.2 (7)
28x0.11
36x0.3
34x0.3
32x0.3
30x0.3
28x0.3
26x0.3
25x0.3
24x0.3
23x0.3
26x0.4
New settings:
KYB Front forks
11x0.3 (3)
20x1.7 (base plate)
12x0.12 <added this
16x0.11
18x0.11
20x0.11
22x0.11
24x0.11
26x0.11
28x0.11
30x0.11
32x0.11
21x0.11
32x0.11 (11)
Piston
Check valve
Spring
Collar
Nut
Stepped washer
8x0.2
Collar
Spring
17x0.3
15x0.3
11x0.3
12x0.11
14x0.11
16x0.11
18x0.11
20x0.11 (4)
20x0.11 (3)
18x0.11
16x0.11
14x0.11
12x0.11
11x0.11
16x1.5 (base plate)
Nut
KYB Rear Shock:
Compression:
22x0.3
24x0.3
26x0.3
28x0.3
30x0.3
32x0.3
34x0.3
36x0.3
38x0.3
28x0.11
32x0.11
40x0.2 (10)
Rebound:
36x0.2 (7)
28x0.11
36x0.3
34x0.3
32x0.3
30x0.3
28x0.3
26x0.3
25x0.3
24x0.3
26x0.4
Hello, do you recommend this setting? I own a Enduro GP and my fork feels "dry" I don't know if you use the word in the EEUU but in the First part it is not sensitive. I feel friction, I don't know if you understand me🙈
Best regards from Spain!!
Old 03-25-2020, 07:40 PM
JoseGas25's Avatar
I have other question. What is the mid valve for? I mean in compression. I would like to try other combinations but I don't know which.
I wrote a post in the Spanish forum, maybe you understand something using the translator.
This is the link:
https://www.2y4t.com/foro/t/113851-r...gas-enduro-gp/
Thank you!!
Old 03-25-2020, 11:04 PM
gg3's Avatar
gg3 gg3 is offline
what sag are you all running on a 2018?
I have a shock 5.6 spring & thought it cornered a little wide so tightened it up to 12mm/102mm. corners way better & still stable at speed.Numbers seem wrong but it works.
Stock settings - Homologation vs Competition jerrytlr Enduro Intake/Carburetion - 2 stroke 6 09-30-2013 04:20 AM
Stock settings for '99 EC200? HELP! RD350 Enduro Suspension 2 07-25-2012 07:54 AM
Stock 2012 ec 300 race stock clicker settings please. bones150 Enduro Suspension 0 05-13-2012 08:16 PM
02 ec 200 stock settings Airborne Enduro Suspension 0 06-24-2007 07:49 AM
03 ec 200 stock settings? Airborne Enduro Intake/Carburetion - 2 stroke 0 06-24-2007 07:45 AM
