Old 10-24-2010, 08:48 AM
Klausen Klausen is offline
Default Indicators don't flash
I would like to install only the 2 direction indicators in the front.
I connect all cabels, plugs and also the flash relais.
But the bulbs don't flash they only shine permanantly.
What can I do ?
Husqvarna TE 300
Old 10-24-2010, 01:18 PM
The flasher relay is set up for four bulbs. With only two bulbs, there's not enough resistance to make the flasher work.
Old 10-24-2010, 10:45 PM
OK when I simulate the 2 rear indicators with 2 resistance (5W/13V = 0,420A; 13V/0,42A = 31Ohm/5W) with appr. 33Ohm/5W it can work?
Husqvarna TE 300
Old 10-25-2010, 04:19 PM
Yes, or you can try an LED flasher.
Most people just hook up bulbs and mount them out of sight.
Old 10-27-2010, 07:47 AM
OK the flashing works with 33ohm/5W but a little bit to slow
may be try some 22ohm resistance
Husqvarna TE 300
indicators not blinking wence Enduro Electrical & Wiring 0 11-15-2008 05:15 AM
News Flash PEB General Discussions & Announcements 11 09-20-2008 08:28 PM
Flash Floods -The Bike Shed in Elba, MN barkeater General Discussions & Announcements 1 08-21-2007 09:39 AM
