Old 05-21-2016, 05:29 PM
Barbs Barbs is offline
Default Closed cartridge Oil weight changes
Hi all.
I am having real trouble finding some straight answers on the net for this.
What is the result on a fork action if I am to change the weight of the closed cartridge oil? If I go to a lighter weight oil does that soften compression and speed up rebound?
I have changed the outer chamber oil weight from 7.5wt to 3wt and have noticed a softer fork action but less bottoming resistance. Would it be beneficial to change the outer weight to 5wt and the cartridge weight from 7.5 to 5wt also?
I am hoping to achieve a similar fork action with slightly better bottoming resistance.
Thanks
Old 05-25-2016, 12:56 AM
Anders Anders is offline
Yes
Thanks
In that case I would keep the oil weight as you have it now and add some oil to the outer chamber.
TTX cartridge for Sachs Enduroger Enduro Suspension 5 05-19-2015 03:24 PM
Why was the Thread on Clay Closed? Moto7man General Discussions & Announcements 11 04-07-2014 05:24 PM
Fork Oil Volume for 2013 Shiver 48mm Closed Cartridge scov Enduro Suspension 3 04-21-2013 02:04 AM
NEPG round 2 Pre-entry closed. mcnut Off Road Racer's Corner 7 12-22-2011 06:53 AM
Ohlins TTX Cartridge kit for 300 09 snaissidis Enduro Suspension 0 11-08-2009 03:17 AM
