FAQ; Suspension baseline settings
2004 to 2006 Models;
A good baseline setting for your Ohlins shock clickers with stock 52 nm spring, stock valving and fresh fluid would be around this range; Rebound, 14 to 16 clicks out. Compression, 17 to 19 clicks out. High speed compression (the 17 mm hex with rubber boot around it) up to late 2005 would be 3.25 to 3.5 turns out. Late 2005 and 2006 has a different HSCD adjuster, 1.5 to 1.75 turns out. The stock 52 nm spring is ideal for 180 lb. rider, +/- 15 lbs max. Your preferences may dictate a variation from this. Set sag (you on board) to 105 to 108 mm. Your preferences may dictate a variation from this. (See more notes towards the end of this post) Spring pre-load (spring free length minus set length) should fall between 10 to 15 mm This is a good place to start and fine tune from there. For the 45 mm Marzocchi fork with standard .42 kg/mm spring, stock valving and fresh fluid would fall in this range; Rebound, 10 clicks out. Compression, 17 clicks out. Fluid level 100 to 110 (total range of adjustment is 80 mm to 130 mm) Stock fluid viscosity is 7.5 Pre-load (spring free length minus set or installed length) 5 to 7 mm. The stock springs are suited for a 180 lb +/- 15 lbs. rider. Your preferences, ability, load (water, tools, etc.) and riding terrain will vary the rates (both front & rear) and adjustments. These are specs for the 200,250,300 2 strokes. Chassis adjustments; The upper fork tube position in the clamps is not a suspension (action) adjustment, it is a chassis adjustment and will determine the steering and higher speed stability. With the fork caps flush to the upper clamp, you will achieve better straight line stability, slower turning charachteristics. (think of it like a raked out chopper) To the extreme of say 10 mm of upper fork tube exposed from the upper clamp, you will have sharper steering and less higher speed stability. The rear sag may be used to fine tune the handling charachteristics as well. With more rear sag, say 115 mm, the rear sits lower and rakes out the front (slower steering, better stability) With less rear sag, say 95 mm, the rear will ride higher and allow it to steer quicker but will give up stability. Combine all of this, and throw in the position of the rear axle position in the swingarm and you have allot of variables to fine tune or totally goof up your bike for your specific needs! |
Great stuff ... thank you.
Does this apply to a 2003?
I guess there is no separate HS damping adjustment? Thanks |
High speed compression Ohlins setting question
I was going through and updating my suspension settings as per Les's suggestions. My High speed compression (the 17 mm hex with rubber boot around it)..goes out a total of 4 turns. I'm curious as to which setting to go with? (up to late 2005 would be 3.25 to 3.5 turns out. Late 2005 and 2006 has a different HSCD adjuster, 1.5 to 1.75 turns out.)
thx/Mike 05' EC300 |
baseline settings for sachs
Does anyone have the settings for the 2007 model with the sachs rear shock, I have an ex-ISDE bike, has the black swing arm.
Thanks |
All of the ISDE bikes came with Ohlins shocks as far as I'm aware.
Call Linton at Dirt Action in Chch, he should see you right. K
08 TXT 300 06 Gasgas EC200 03 Gasgas EC300 05 Pampera 250 |
Sachs
Hey thanks for that, It is very much a ISDE bike still has all the paint marks on all the parts, it was ordered with the sachs rear shock & to be fair my last gasser had the Ohlins & like the sachs better, what I was after is the high speed setting as the manual has no information on it at all & the NZ importer does not know ether.
The following tips are off the Too Tech Racing web site:
Setting sag http://www.tootechracing.com/suspension_tips.htm Setting static sag http://www.tootechracing.com/Static%...sion%20Tip.htm Tons of suspension info here http://www.tootechracing.com/Home%202nd.htm |
I have a 1999 EC250 You talk about rebound and compression. on my front forks there is a blue knob at the top. On the bottom of the forkleg there is no other adjusting screws. Does the top adjuster just set one or both of the rebound or compression??
As I remember, left knob is for the compression and right for the rebound. 8 clicks out for either is the standard setting.
Thread Tools | |
Display Modes | |
Gas Gas EC 300 09 Basic Suspension Settings | snaissidis | Enduro Suspension | 0 | 03-16-2009 04:05 PM |
2005 baseline settings | stay_upright | Enduro Suspension | 0 | 01-26-2009 08:37 AM |
450 fork settings? | splint | Enduro Suspension | 0 | 10-14-2008 03:30 AM |
baseline ohlins setting | fullthrottle | Enduro Suspension | 5 | 04-26-2008 08:15 AM |
EC300 Baseline settings | Magellan | Enduro Suspension | 7 | 08-26-2006 06:30 AM |
