I did my first top end since I bought it and the power valve has no bearings on one side. Has anyone seen this? Pic attached. You can see the bearing on the one side. On the other side there's a bushing? No bearings. I don?t have a legit manual. I have a later manual showing two bearings on that side but I don't know what was supposed to be on this particular bike.
EC250PowerValve.jpg |
not sure about 1997, but more recent bikes have 2 bearings on the side of the bush. so you would need 3 bearings like the one you have
https://www.motocrosscenter.com/shop...-parts-manuals
I'd swap the existing bearing over for size, to see if it would work, then as Swazi sez try it. Can't see why it would be different. But 'despice' (probably Spanish for Parts list) pdfs may be available for that far back.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) Last edited by (F5); 04-02-2024 at 01:46 AM. |
I have a 99 engine parts rich and it shows 2 bearing if that helps, the bearing are the same size I buy them off ebay for cheap.
Thanks all. I had a feeling. Makes no sense it would be different. I should tear it back down and do bearings. It ran great for a good while when I bought it and it's been like this. I have a feeling I'll be lazy about it. But damn, I should not be.
Should just pull out the side with pipe off or tap through.
Old EC250 idle issue and power valve leaking... | 2ndGen | Enduro Intake/Carburetion - 2 stroke | 4 | 09-08-2021 09:49 PM |
1998 ec250 power valve tuning | lymebayroofing | Enduro Engine - 2 stroke | 5 | 12-30-2019 08:25 AM |
Side cover power valve bearings? | Terrence R | Enduro Engine - 2 stroke | 19 | 04-29-2016 07:26 AM |
Power Valve Bearings - What Type? | JP4 | Enduro Engine - 2 stroke | 3 | 04-22-2015 02:12 PM |
Checking for proper power valve operation 2003 EC250 | SideshowBob | Enduro Engine - 2 stroke | 4 | 04-08-2010 01:00 PM |
