Old 12-19-2013, 07:54 PM
Bandit9's Avatar
Bandit9 Bandit9 is offline
Default 2 Thumbs Up on 48 CC Zokes!
Just wanted to say that I'm impressed with the 48mm CC Zokes. My tuner did a good job. They feel just as good as the KYB SSS forks that were on my YZ250. Which I didn't think was going to be possible, but the performance in the dirt don't lie. I can pretty much hit anything from roots to whoops to jumps to G outs and they suck it all up with no fuss. It is going to get better too, I still have haven't played with the PFP and I'm still fine tuning it.
Blanco
Current ride: 2009 WR450
Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F
Old 12-19-2013, 09:29 PM
AZRickD AZRickD is offline
Funny you should mention the PFP. I googled info on adjusting with it and I am as yet not quite sure what it does and when to use it.
As far as the 48mm Zokes go , the biggest plus is its ability to soak up big hits ( either G-outs or jumps). In stock form both the fork an 888 Ohlins shock are too stiff and very lacking in rebound. The forks required two shims worth of bleed to soften them and about the same in the rebound stack.
Old 12-20-2013, 12:32 AM
2 shims worth is a bit vague
I'm still working on breaking mine in. They were pretty stiff out of the box, but don't feel all that bad after a few minutes. I imagine they'll get better.
From what I understand the PFP is like changing the ICS in a set of KYB/Showas. (The internal spring). Or increasing the pressure on a WP Bladder fork.
Less preload can plushen up the initial action of the fork, while cranking it down will firm it right up. I don't imagine it will be something that I use too much. More likely I'll set it towards the midde and then work on the stacks.
Old 12-20-2013, 12:34 AM
Banned
The PFP is basically an external pre-load adjuster.
Old 12-20-2013, 12:51 AM
http://shimrestackor.com/Code/Sample...S/ics-perf.htm
Old 12-20-2013, 05:13 AM
Simmo737's Avatar
Simmo737 Simmo737 is offline
I agree. It increases the amount of hydraulic pressure that has to be overcome prior to the damper rod moving in the cartridge, it's preload.
The cool thing about it is that the ramp from preloaded to movement can theoretically be controlled by shim stacks, and then you can vary the ramp with a change in pfp preload, it's much more complicated than a simple spring preload variation, but appears the same. I think that it adds almost too much variability, bit like the shim controlled bottoming valve and needle variable pds style valving in 4cs forks, tuners are struggling to unlock the more tunable aspects of both systems, but it all holds a lot of promise. All IMHO
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 12-20-2013, 05:42 AM
Agree Simmo. Its the pressure on the inner cartridge, or if you think of it like a shock its similar to varying the N2 pressure. A big consideration is that if running not much PFP and relatively stiff stacks it may cause cavitation in the chamber. I think for me personally, I'll be simply trying to tune the stacks to work, and then using as little PFP as required.
Old 12-20-2013, 08:30 AM
What behaviors would I use tha PFP to tune ?
Old 12-20-2013, 09:51 AM
twowheels's Avatar
It's worthwhile running a lighter rate or shorter PFP spring as well. That makes the adjuster effective up and down.
PlusOnePerformance
Steven Beane #275
afterhourscycle.com
Old 12-20-2013, 08:17 PM
twowheels's Avatar
Originally Posted by Simmo737 View Post
Also am I right in saying that once you've overcome the preload the spring rate Increases at the standard rate, 1.5 kg/mm or whatever so it actually is only a higher cartridge pressure until the spring is moving from a point where it would be at the same preloaded or unpreloaded. This is the value of a spring vs gas pressure.
My brain hurts.
Convert the preload to a pressure needed to deflect. You can always resolve to a force or pressure since you know (presumably) the piston area.
PlusOnePerformance
Steven Beane #275
afterhourscycle.com
48mm zokes? wence Enduro Suspension 5 04-30-2013 02:35 PM
New Zokes Fred1956 Enduro Suspension 2 12-05-2012 12:35 PM
50mm zokes on an '05 EC 300? siaknijustin Enduro Suspension 3 10-23-2012 11:24 PM
Help with Rebound 11 Zokes Tlineman Enduro Suspension 12 07-26-2011 04:34 PM
48mm zokes dublin Enduro Suspension 0 06-05-2011 05:34 PM
