Öhlins 888 shock no clicks at the HS screw
My rear shock in a 50h used Gasser was losing the nitrogen complete.
There were a X-ring broken. I send it to the tuner. Today I wan't to set up my shock to the recommended adjustments. I can feel the clicks at the rebound wheel and the low speed comp scew in the middle. But when I turn the 17mm hexagon HS Comp screw I feel nothing - no clicks. This is my first HS LS Shock - is this normal?
Husqvarna TE 300 |
Das ist richtig.
OK the description from the tuner was incorrect no clicks only turns on the HS screw
Husqvarna TE 300 |
big advantage Öhlins 48 fork to Shiver 45? | Klausen | Enduro Suspension | 10 | 11-26-2010 10:52 AM |
2005 öhlins shock fits 2010 EC300 | bergerhag | Enduro Suspension | 17 | 10-26-2010 11:57 AM |
Öhlins Shock 2004 fits in newer Gasgas | Klausen | Enduro Suspension | 3 | 05-06-2010 10:53 PM |
07 ec300 with öhlins/öhlins | gasmonaut | General Discussions & Announcements | 4 | 10-31-2006 11:31 AM |
