Old 07-06-2014, 05:50 AM
Default what forks to use
Hi all im thinking about modernizing the old girl as im starting to find the 45 zokes crap.
ive been looking in to kyb sss or the Honda crf showa . I personally would like some that just bolted straight up but from reading stuff that does not look possible can the original clamps be used with mods etc
what is needed for the kyb and what do I need and from which year
the Honda showa again what's needed and what do I do
what about ktm wp or is it a new bike but the new one are out of my price range at the mo
thanks in advance for info
03 ec300
honda cr500 94
Old 07-06-2014, 06:33 AM
Search BrantMartel for his 47mm Showa Conversion. Believe he may have ran the honda brakes, front wheel, axel, and forks with some machining and mods to the OEM 45mm triple clamps.
KYB is similar approach but use Yamaha triples too. Lots of info in a thread for this.
I wouldn't waste you time with WP. Will have to go through the conversion process and still end up with a so so result. From what I read on the 'other site', some of them are going the Showa route.
Old 07-06-2014, 08:36 AM
Cheers mate would the honda yokes fit
03 ec300
honda cr500 94
Old 07-06-2014, 09:31 AM
Caravan Monster's Avatar
What problems are you having with the 45's ? There might be a solution by working with what's already there instead of starting again from scratch. Also, putting time and money into extensive modification of a 10 + year old bike might be false economy.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 07-06-2014, 09:59 AM
Yeah man I fiollow ya there that's why I'm trying to see if it's worth doing
Basically I feel every bump and am fighting with the bike, I noticed it after riding a crf and the glided over it all nicely
I am going to have a play with the forks next time I'm out at a enduro practice
03 ec300
honda cr500 94
Old 07-06-2014, 04:20 PM
gasmonkey's Avatar
Bronze Level Site Supporter
A suspension guru should be able to make them work fine.
Old 07-08-2014, 11:02 PM
djroggen's Avatar
djroggen djroggen is offline
I sent my forks to Drew Smith WER in PA and he turned my 45 Zokes into some very good forks. Very good in the rocks and roots still to be desired on an mx track.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 08-13-2014, 07:53 PM
Well I've taken the plunge & bought a set of local '06 YZ250 sss forks, axle & triples. I'm probably going to try mod the triples to get steering rotation stops but we'll see. Biggest thing to do first is machine up a caliper mount as I'm too cheap (out of funds) to buy the braking one.
Thanks for the ideas esp Eric.
Old 08-13-2014, 09:33 PM
nknudsen's Avatar
nknudsen nknudsen is offline
On my 08' SSS forks (different caliper mount than your 06) I used / modified the oe GG caliper mount. One mounting hole lined up and I just welded one mounting hole shut and drilled and tapped a new one. Just get crafty if you need to. I did shim it out from the forks with a couple shim washers to center it on the disc.
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 08-14-2014, 12:52 AM
Cool, yeah I'd read that post during my research. I've done a few brackets for road & roadrace bikes so I'm not that scared of it, but I could do without $80 & shipping added onto the conversion cost. Better spent on bearings for which I'll need steering & smaller ID front wheel by the looks.
I usually dummy up plates in plywood to get the holes aligned & then transpose to allly.
Which used forks do I have? wmcpb04 Enduro Suspension 17 06-11-2013 07:59 PM
forks robicon Enduro Suspension 2 05-08-2012 02:42 PM
43 mm wp forks. jhendr3702 Enduro Suspension 4 10-18-2010 06:46 PM
forks sen480 General Discussions & Announcements 1 03-25-2010 04:54 AM
