Old 02-05-2008, 09:22 PM
MattR's Avatar
MattR MattR is offline
Thumbs up Jetting Database - PLEASE ADD YOUR SETTINGS
Here is a summary of the Jetting Database:
Click Here --> http://www.gasgasrider.org/forum/showthread.php?t=3800
How to enter your jetting data:
I thought it would be useful to start a GasGas jetting database. The goal is for people to just list what they are using (or have used). It will be important to follow a "common format" in order to allow quick comparison of data.
IMPORTANT:
It will be beneficial that users list only ONE bike setup per post. If you have several temperatures/conditions for the same bike, please list them in separate posts. Likewise, if you own multiple bikes, please list them in separate posts.
Also, please do not post questions in this thread. If you have a specific questions, start a separate thread so others can respond.
Database Format
{Copy & Paste the following lines in your post}
Bike year & model =
Temperature (degF) =
Elevation (feet) =
Main jet =
Pilot jet =
Needle & notch =
Air screw setting =
Throttle valve/slide =
Results:
Thanks!
Matt
Current: 2009 Yamaha FZ1
Last edited by MattR; 12-18-2008 at 08:45 PM. Reason: Modified statement to indicate one bike setup per post.
Old 02-05-2008, 09:27 PM
MattR's Avatar
Bike year & model = 2007 EC250
Temperature (degF) = 25-35 degF
Elevation (feet) = Sea level to 1000 ft
Main jet = 185
Pilot jet = 45
Needle & notch = LTR, #3 notch
Air screw setting = 1 turn out
Throttle valve/slide = #7
Results:
The throttle response was good from idle to 1/2 throttle (i.e., the pilot and needle clip were good). With the 180 main jet, I'm getting some hesitation around 1/2 to 3/4 throttle. I changed to a 185 main jet. This helped the upper range. I noticed the bike had hesistation around 1/4 to 1/2 throttle in rain mode. In sun mode, it felt better. Also, I use Amsoil Dominator at 40:1 mix with 94 octane fuel.
Matt
Old 02-05-2008, 10:17 PM
widebear's Avatar
widebear widebear is offline
Banned
2003 MC250
Temperature (degF) = 40-85 degF
Elevation (feet) = Sea level to 5000 ft
Main jet = 172
Pilot jet = 35
Needle & notch = N3YF, #3 notch
Air screw setting = 1.5 turn out
Throttle valve/slide = #9
Amsoil 100-1
Results:
Throttle response is outstanding everywhere, very good idle and very good cold start properties as well.
Old 02-06-2008, 01:40 AM
Loosenut's Avatar
Loosenut Loosenut is offline
Bike year & model = 2005 EC300
Temperature (degF) = 30 - 60
Elevation (feet) = sea level to 4000
Main jet = 172-175
Pilot jet = 42
Needle & notch = CCK #3
Air screw setting = 1.5 - 2
Results: Bike has RB headwork. This jetting results in a smooth power taking advantage of the headwork and making the power smooth, yet ample. Prior to the headwork, I used the LTR needle,#3 clip position and the #8 slide.
Old 02-06-2008, 07:12 AM
iancp5's Avatar
iancp5 iancp5 is offline
Bike year & model = EC300 2003
Temperature (degF) = 32 - 55
Elevation (feet) = 0 - 1000
Main jet = 180
Pilot jet = 42
Air screw setting = 3
Results:
Smooth
Old 05-16-2008, 09:42 PM
widebear's Avatar
Banned
2001 ec-300 with motocross ign and RB style head mod
Temperature (degF) = 40-90
Elevation (feet) = 2200- 5800
Main jet = 165 messico & doma pipe, 170 fmf pipe
Pilot jet = 35
Needle & notch = Kawi N3YF #3 notch
Air screw setting = .75 turn out
Results. Very crisp throughout the rpm range, pulls hard with instant throttle response and good high rpm power , Caveat , would not ride in sand with this small a main jet, 10 minute road section at W.O.T. with no problems and no overheating
Old 02-08-2008, 05:30 PM
Temperature (degF) = 45 - 65 degF
Main jet = 182
Pilot jet = 48
Needle & notch = LTR"-0" #3
Air screw setting = 1.5 turns out
Results:
Runs clean and strong, not much to complain about. Drop to 45 pilot in summer to clean up idle, thats it.
Old 02-08-2008, 05:41 PM
Main jet = 182
Pilot jet = 48
Needle & notch = JD Blue #3 (from JDKH01 kit)
Results:
Very much like the LTR -0 needle, perhaps a little crisper response off the bottom. Idles very clean. Drop to 45 pilot and adjust air screw in summer, thats it.
Note:
This bike is very tolerant to environmental changes and was very easy to dial in. Eaisest bike I ever jetted. Makes great power in both map settings with great milage.
Old 02-19-2008, 05:32 AM
eff's Avatar
eff eff is offline
Bike year & model = 2004 DE250
Temperature (degF) = 35 - 50 degF
Main jet = 178
Pilot jet = 48
Needle & notch = LTR -0 #4
Air screw setting = 2-2.5 turns out
Results:
Bike runs clean and smooth in colder weather. As the temperature warms above 50º I will move the clip to #3 and adjust the air screw as needed. Above 70º and I move the clip to #2.
Old 02-19-2008, 09:55 AM
cladoo's Avatar
cladoo cladoo is offline
Bike year & model = '07 EC300
Temperature (degF) = 20c
Elevation (feet) = 3500'-6500'
Main jet = 165
Pilot jet = 40
Needle & notch = LTR -2
Results: I run Amsoil Dominator @ 50:1 ,Iridium NGk plug, no other engine mods. It works great.
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
