Old 02-23-2012, 01:19 PM
GasgasTom GasgasTom is offline
Default Rekluse for my 515 FSE
Hallo,
does anybody know, if there is the Rekluse automatic clutch to buy for my 515 FSE. No offer on their homepage but I have seen the clutch on older 450.
Thank You and greetings from Germany
Old 02-23-2012, 01:51 PM
djroggen's Avatar
djroggen djroggen is offline
The same as every other GasGas clutch. So any of the 200(2t)/250(2t)/300(2t)/450 Rekluse stuff will fit.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 02-23-2012, 02:53 PM
Hallo, don?t think so. 2 stroke and 4 stroke must be different because of the extra gear (oil-pump-drive). Hope the older 450 Clutch would fit but the part-number of the clutch assembly is different.
Old 02-23-2012, 03:01 PM
djroggen's Avatar
Fibers and metals are the same part numbers for the 515 to the 2 strokes, unless you are replacing the whole basket assembly, the basket itself is the same. (Basket that holds the fibers is the same but there are different gears behind the basket hence the assembly part number being different)
Have a good one.
The only thing that I can think of is that the springs are different between 2t and 4t. The 4t springs are just a little stiffer.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Old 02-24-2012, 01:05 AM
Hallo, I think, that makes the difference. The basket is annother type.
Thank You, greetings from Germany.
Still hope, Rekluse gives me an answer.
Old 02-24-2012, 06:01 AM
Sorry, I?m wrong. Thought, I must have a Rekluse Z Start Pro but Core EXP will fit. So I need not change the basket only the inner parts. My dealer will order it.
Rekluse exp. blanc General Discussions & Announcements 46 04-10-2012 02:31 AM
Rekluse exp now available? firffighter General Discussions & Announcements 28 07-08-2011 11:13 PM
Rekluse EXP 2.0 for Gas Gas? AZRickD General Discussions & Announcements 13 05-25-2011 06:44 AM
