Rekluse Core Manual
This week I installed the Rekluse Core Manual on my bike.
My clutch would squawk really bad under a heavy load. I did a good shake down run today. The Rekluse Core Manual completely corrected the noise issue. Finding neutral is a lot smoother. No clutch drag when the lever is pulled in. The engagement point is the same as stock. As you can see in the pics, there's a LOT more oil flow to the clutch plates. Overall, this is an excellent mod. It is 100% plug and play. No adjustments needed. The Rekluse comes with: Pressure plate, Inner hub, Steel plates, Springs with bolts and spacers, lock washer ,and throw out bearing. OEM inner hub. Closed off-no oil flow. Rekluse- open back shown. OEM pressure plate- closed off. Rekluse pressure plate. |
Great looking and they work sweet I have been putting the Recluse Auto clutch in all my enduro bikes . They do need to be adjusted as they wear but that is to be expected . I have not had a manual but I bet it is like the auto clutch , that is really nice . Give it a good beating and see how it holds up .
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES |
The engine seems to rev a little faster.
Now I see why, there's a lot less rotating mass with the Rekluse. |
Now the big $ question , how much for the manual clutch ?
Thread Tools | |
Display Modes | |
Rekluse Core EXP 3.0 | d251man | Parts | 5 | 10-03-2016 06:05 PM |
rekluse core manual question?? | nambo-trev | Enduro Engine - 2 stroke | 3 | 02-15-2014 06:12 PM |
Looking for a Rekluse Core EXP | myrcrocks | "Wanted to Buy" & "Want To Trade" | 7 | 02-03-2014 11:06 AM |
rekluse core exp 2.0 | leeroybrown9 | Parts | 0 | 07-26-2013 03:23 PM |
Rekluse Core EXP | blanc | General Discussions & Announcements | 13 | 03-01-2011 08:35 PM |
