Torque Specs
Are the torque specs for the head and jug on the links for this web site accurate? If not could someone give them to me?Thanks.
Be sure to retorque the head and jug fasteners after a couple heat cycles. I didn't last time and sucked the base gasket out of alingment.
Paul B |
Do you think the head and jug fasteners should be retightened on a new bike after a few heat cycles, or only after a new top end.
Also, are the above torque values applicable to lubricated fasteners or unlubricated fasteners? I always lube the bolts on my bikes especially since so many connections involve dissimilar metals (steel and aluminum). |
I don't know about the new bikes, I have never owned one(poor me).
( quote) Also, are the above torque values applicable to lubricated fasteners or unlubricated fasteners?
I'm almost 100% sure its for unlubricated nuts and bolts. |
Thread Tools | |
Display Modes | |
05 De 300 Specs | VORMAN | Enduro Electrical & Wiring | 9 | 11-14-2010 06:36 PM |
Top End Clearances/Specs | SpeedyManiac | Enduro Engine - 2 stroke | 4 | 09-24-2009 09:53 PM |
rake and trail specs | widebear | Enduro Chassis & Body | 9 | 01-28-2009 05:52 PM |
ring gap specs | jostby | Enduro Engine - 2 stroke | 9 | 10-27-2008 06:18 PM |
Chain and Sprocket specs | gasIdaho | Enduro Chassis & Body | 7 | 09-01-2006 04:03 AM |
