Old 11-08-2020, 12:37 AM
brads1725 brads1725 is offline
Default Marzocchi Oil Change
Hi All,
I am keen to do a fork oil change on my 48mm shivers, no leaks at the moment so just want to dump the old and in with the new.
Has anyone of a guide or how to for a quick oil change?
Cheers
Old 11-08-2020, 09:49 AM
SS109 SS109 is offline
Are you wanting to do a complete oil change or just the outer? Outer is super easy but considering the inner and outer mix it's not the best option. Doing a complete oil change is a lot more involved but well worth it IMO.
I did a video showing how to completely service the Marzocchi fork. A lot of steps you can skip for either type of fluid change. Hope it helps.
https://youtu.be/dbKjhvFl7AQ
Old 11-08-2020, 12:06 PM
I didn't realise there was an outer and inner, yeah want to get it all changed out like you say, otherwise its a waste of effort. Ill have a good look at your video and see what I can do
Old 11-08-2020, 12:08 PM
Do you refill based on height or a volume on these forks? I haven't messed with forks much before. Got the Marzocchi manual, and the specs there but read a bit about going off the levels instead
Old 11-08-2020, 05:20 PM
Yeah, they say levels but I go volume and it's well.
Old 11-09-2020, 02:46 AM
Great video, think I'll just pop the inner, fill to 140 and put it back together. I see you went with 5W oil, how did that go? I try to ride more aggressive and am at 185lbs so thinking the 7.5 might still be better
Old 11-09-2020, 01:25 PM
I'm an aggressive B rider. I weigh 140 lbs. The 5w oil works great and is all I use in all my forks.
Know that just because something says it's 5wt, or any weight, doesn't mean that's the actual weight. To truly know you need to find out what the spec of the viscosity at 40c is for proper comparison. The oil I run is 26.1 @ 40c.
Old 11-10-2020, 12:58 AM
Anders Anders is offline
I am an old, slower rider. I use KYB 01M fork oil which is approx 15 cst at 40C. I did also do some revalving to obtain less compression (and slightly more rebound) damping. Works very well for me.
Old 01-08-2021, 12:11 PM
Down2fix Down2fix is offline
There was a firk oil comparison chart float around that one if the members put together years back.
Maybe someone has the link
2011 ec250 all the scorpion racing goodies, fmf gnarly, lector carb, fully setup for hare scrambles.
Old 01-08-2021, 02:35 PM
Is this the one?
Oil change on Marzocchi 48 (2014) adriano.ro Enduro Suspension 1 11-11-2016 04:52 AM
'03 450 FSE oil change raoufhakam Enduro Engine 4 stroke (including EFI & Exhaust) 1 03-26-2016 03:53 AM
Oil change Vinny Enduro Engine 4 stroke (including EFI & Exhaust) 7 05-25-2011 09:37 PM
Marzocchi Fork Oil Change eff Enduro Suspension 19 04-03-2008 07:55 AM
Oil change... FFRDave Enduro Engine - 2 stroke 14 06-29-2007 11:14 PM
