Old 11-09-2020, 07:28 AM
Johangas Johangas is offline
Default 2006 Marzocchi shiver 45mm outer tube crossfit
Hi
I have a ding on my outer tube, just where the seal is seated.
Tried to straighten it out but the tube cracked, welded and grinded but got a to big seal seat. Leaks alot of oil.
Looking to buy a new outer tube, the only ones i have found are the ones from husky shivers. They look identical. Anyone have knowledge about the husky outer tube? They take a month to ship so it better fit!
Any clues or good ideas?
Old 11-09-2020, 11:26 AM
The Husky forks probably wont fit. You'll run into axle fit issues.
e-bay has some forks for sale.
https://www.ebay.com/itm/GasGas-FSE4...AAAOSwPlFedETc
Old 11-09-2020, 01:10 PM
Cheers gasgasman.
So you think marzocchi shiver outer tubes on the husky be different?
They use the same seals so i thought the only issue could be the fit in the tripple clamp.
Im only looking to change the outer tube.
Old 11-09-2020, 09:07 PM
I'm sorry. I misread your post.
The Husky outer tubes would probably be the same.
To save manufacturing costs, I doubt Marzocchi would have different tubes.
Old 11-10-2020, 03:14 PM
I have ordered husky outer tubes. I will write later how they fit if ever anybody else break there outer tubes.
Old 03-17-2021, 01:46 PM
Smile
Ok, so I finally managed to put new outer tubes on my fork. The husky tubes where almost identical, but where little bit wider in the lower clamp. Was super snug so i had to bend the lower clamps abit when fitting the forks. Might have been 1mm wider in the lower clamp. But all else was the same.
The tubes got stuck in customs for like 2 months, so it was a bit of a hassle.
If anybody ever need to change outertubes, husky shivers will work.
Old 03-17-2021, 06:42 PM
You may want to take some accurate measurements of the OD of each fork tube (old vs. new) to ascertain if the diameters differ at all. You may have issues with the action of the fork and/or premature wear of the fork components if the clamp was not designed for that specific diameter of tube at the lower clamp. ie. binding
It would be a simple enough to have the lower clamps machined to the correct ID if needed.
marzocchi 45mm shiver johall865 Enduro Suspension 0 12-28-2014 06:55 PM
wtb marzocchi shiver 45mm mbogage "Wanted to Buy" & "Want To Trade" 7 04-06-2014 09:46 AM
wtb marzocchi shiver 45mm mbogage Parts 1 01-12-2014 09:21 PM
Marzocchi Shiver 45mm piston mcnut Enduro Suspension 7 01-15-2012 08:40 AM
Marzocchi 45mm Shiver manual super_rat Enduro Suspension 1 01-01-2009 10:24 PM
