Old 09-29-2009, 09:20 AM
iancp5's Avatar
iancp5 iancp5 is offline
Originally Posted by GasGasser View Post
Anyone? Which are the standard clicker settings? I can't find out from the manual.
These are some settings I worked with. Not saying they're right for you though! The first setting is where I am now, the others are different people's recommendations including standard. My settings WILL be very different from standard because I am running 0.46 springs up front and a 5.7 on the rear.
Rear shock:
Rider Sag 105-110mm
Static Sag 25-35mm
Clicker starting position.
Rebound 15 clicks out from full in or max rebound (mh & std = 18 from in) (LTR 14 -16 out)
Compression 2 clicks off full soft (mh = 16, std = 20 from in) (LTR 17-19 out)
Forks:
110 - 120 mm air gap
Rebound 10 clicks out from full in or max rebound (mh = 6 std = 12 from in, LTR 10 out)
Compression 6 clicks off full soft (std = 12 from in) (LTR 17 from in)
Old 10-01-2009, 12:57 AM
GasGasser GasGasser is offline
Thanks a lot, now I have something to start from!
Just have to wait another week to get riding though as the doctor decided to remove some unnecessary bits and pieces from my throat
Old 10-01-2009, 12:45 PM
iancp5's Avatar
Oooh sounds nasty! Or was it just tonsils.
Old 10-02-2009, 03:15 AM
Yes, it was just the tonsils, nothing too bad but I keeps me from riding a couple of weeks And from speaking a couple of days But it's almost healed now, so next week I hope to go riding. And again, thanks for the info!
Cheers!
Old 09-28-2012, 12:23 PM
puffy puffy is offline
Hey there, I have a 2011 ec250 Marzocci forks and an Ohlins shock. I'm running stock springs and weigh 150lbs. I'm struggling finding a good dry "no grip" set up on the forks. The shock can be made to hook up but the front end feels on top of the ground in the corners, almost shovey. Any suggestions?
Old 03-02-2013, 10:42 AM
Gibby Gibby is offline
Default New XC 300R :-)
Just picked up a new XC 300R from Mort's Powersports in Mobile, Alabama.
John the owner is a great guy and has been very helpful trying to help me get the bike dialed in, I have had the bike for 2 months and have put 10 hours on it. I will be riding mainly South Alabama Woods, Tight, Technical, Roots, Sandy, Hills and mud. I am 40 years Young, I have only been back riding for 1 year after a 7 year break, I raced in SERA Southern Enduro Riders,
in my late 20s early 30s. before that I rode alot but not raced.
I am 6ft 200 lb
South Alabama: Hot, Humid, Sea Level.
So far:
Main Jet: 172
Pilot Jet: 40
Airscrew: 1.5
Needle stock in the top clip,
Slide; stock
Fuel: 93 octane 100% unleaded, (no corn) 44to1 Golden Spectro.
Took a minute to get it lean enough. Seems to have good crisp power all the way through the power curve, rain setting. Still has alittle spooge but atleast I know there is lube.
Suspension seemed very ridgid at first, bounced in the rear over roots and square edges, divey in the front end going into corners.
Changed back tire to Michilin sc12wc (much better than stock)
backed off rear spring preload 2 turns, low speed compression 16 out,
rebound 20 out,
Front Forks: recieved with pfp all the way out. I Turned in 1.25 turns,
Compression 16 clicks out, Rebound 14 clicks out.
Seems alot better than stock but i like it soft and plush. I will call Evan at
Solid Performance, when i am ready for service and revalve, Hopefully he can help me plushin it up.
Allso moved bars to forward position. Cut 3/4 inch off both end of bars and added Cycra bark busters, Mounted light switch inside front number plate.
Love the 300 POWER, I can leave it in 3rd and work the clutch.
Bike Really promotes standing.
Any hints or tips would be greatly appreciated.
Josh Gibson
joshgibson@aencservices.com
13 XC300R (LUV IT)
02 DRZ 400 S, Great bike to get to work.
97 KTM 250 SX Awesome Machine But Needs LUV.
09 YZ450 Going to set up for woods.
99 KTM 300 MXC SOLD
97 KTM 250 EXC SOLD
92 KTM 250 EXC SOLD
LOTS OF OTHERS
FIRST BIKE 79 KX 80
Old 12-31-2014, 04:49 PM
2taddict 2taddict is offline
@ 90kg geared up, I am thinking of getting 4,3 or 4,5 Ohlins fork springs & 54 or 56 Ohlins rear spring.
The bike 2006/ec300 currently has a 58 rear not sure what's up front. I was told by the dealer the last guy that had it was about 115kg.
What difference can I expect from 4,3/54 compared to 4,5/56?
Old 04-05-2019, 12:15 AM
Banditpowdercoat Banditpowdercoat is offline
Hi all. This may have been posted but there's a lot to go through on this thread I. Looking for any info on setting up a 1998 ec250. Ohlins rear. Zoke 44mn front. Prevowner had heavier springs installed. He's about 250 or so lbs. I am 203 out of the shower I they should work. But is the standard 100ish mm sag for rear applicable? What about front? And clicker settings? No racing. No track or large air. I am a backwoods single track rider. Rocky British Columbia single tracks.
Old 04-05-2019, 11:46 AM
GasGas's Avatar
GasGas GasGas is offline
Just put 10mm of preload on your shock spring and try that. Always seemed to work great on the older bikes with the ohlins shock. The owners manual has good set up tips for the clickers. It can be found on the GG web site.
2018 EC 300
Old 04-06-2019, 06:51 AM
RBrider's Avatar
RBrider RBrider is offline
Cheers!
I seem to recall that I got to eat lots of ice cream when I was recovering from that surgery. So there is a bright spot there.
RB
Gas Gas EC 300 09 Basic Suspension Settings snaissidis Enduro Suspension 0 03-16-2009 04:05 PM
2005 baseline settings stay_upright Enduro Suspension 0 01-26-2009 08:37 AM
450 fork settings? splint Enduro Suspension 0 10-14-2008 03:30 AM
baseline ohlins setting fullthrottle Enduro Suspension 5 04-26-2008 08:15 AM
EC300 Baseline settings Magellan Enduro Suspension 7 08-26-2006 06:30 AM
