Old 10-27-2010, 03:41 PM
Bradz Bradz is offline
Default 2010 Sachs Fork Seals
Does anyone know what size the fork seals are for the Sachs, and are there any crossover parts available.
Cheers Brad
2010 EC 300 and counting
Old 10-28-2010, 06:37 PM
Keg Keg is offline
KTM 48mm are the same.
Old 10-28-2010, 10:52 PM
yep you can use the ktm 48 x 57 x 9.5/10
I hate to say this, but i think they are better than the GG ones. Especially if you use a degreaer to clean your bike, the GG ones tend to dry out and get v tight on the forks affecting suspension
Old 10-28-2010, 11:04 PM
Pelle Pelle is offline
The SKF seals are outstanding, no need to use WP (imho). When i had a -03 with wp43, they constant leak and i was changing about 3 times a year... The SKF have last for 14 month, and the new replacement was really smooth and easy to install!
Old 10-29-2010, 02:48 AM
reason i said the skf were not good is:
1 It is impossible to remove the dust seal without damaging it. I do this every time i ride muddy stuff and i remove the dust seal and clean out all the fine dirt with wd40
2 when i adjusted the oil level i had to really push the tube down over the inner which led me to believe that they were very sticky and/or tight.
maybe it is a result of the detergent i use (prepsol) but the ktm seals slide better (and as a result will possibly weep)
Old 10-29-2010, 06:20 AM
widebear's Avatar
widebear widebear is offline
Banned
Allways, allways use silicone spray lube, and stroke them after spraying, on your hard chrome tubes and shock shaft after washing with harsh detergents.
Old 10-29-2010, 10:40 AM
thanks for the information guys, its a great help
Old 01-04-2011, 12:06 PM
garacerx's Avatar
garacerx garacerx is offline
I have found wd 40 to shorten fork seal life- it attacks certian types of rubber. Dont reccomend using as a cleaning agent for seals.
2010 Sachs EC300 Fork Problem Bradz Enduro Suspension 4 07-17-2010 03:21 PM
2010 Sachs fork factory compression stack specs(ec300) bergerhag Enduro Suspension 9 07-01-2010 11:18 PM
Fork seals Iron Hide Enduro Suspension 2 02-22-2008 12:45 PM
wp fork seals dlwheaton06 Enduro Suspension 4 12-23-2007 06:34 AM
