Old 07-18-2006, 05:23 PM
Magellan Magellan is offline
Default EC300 Baseline settings
I recently had my forks set up by Les (www.lt-racing.com) and was very happy with the results.
On Saturday, I was racing and felt like the rear wheel is bouncing off of things more than I would like (it was a rocky course). On Sunday, I went to make some adjustments.
My first thought was that I had too much compression dampening on the shock, keeping it from sucking up the hits from thee rocks. When I went to soften it up, I discovered that it was already set as soft as it would go.
So now, I think i want to start over with a recommended baseline, and go from there.
I'm looking for good starting places. Primarily for the rear, but will take recs for teh front as well.
James
2004 EC300 -- LTR Stuff, RB Designs Carb Mod
2016 Africa Twin
1975 Honda CB400 F1 (X2, projects)
2019 RE 650INT
1982 KDX80
2017 KAW EX300
1982 XL500R
2015 HUSKY FE501S
1972 HON CB175
Old 07-19-2006, 12:02 PM
LTRace's Avatar
LTRace LTRace is offline
Hello James,
A good baseline setting for your shock clickers with stock 52 nm spring and stock valving would be around this range;
Rebound, 14 to 16 clicks out.
Compression, 17 to 19 clicks out.
High speed compression (the 17 mm hex with rubber boot around it) would be 3.25 to 3.5 turns out.
Set sag (you on board) to 105 to 108 mm
This is a good place to start and fine tune from there.
From what you describe, it sounds to me the rear is kicking back on you meaning a loss of rebound damping. I would be willing to bet you are due for a fluid change and service. When the fluid breaks down in the shock, the rebound action is the first to suffer. As a general guideline, if you have to increase rebound damping to get your control back to what it was, you are due for a service. Take care,
Les
www.lt-racing.com
Port Orchard, WA USA
Old 07-19-2006, 07:34 PM
barkeater's Avatar
barkeater barkeater is offline
Les is the Gas Gas suspension god.
Listen to the master. My EC/O 200 is dreamy after I sent the suspension to LTR.
Old 07-19-2006, 08:14 PM
Agreed. He did my forks recently....sounds like he'll be servicing the shock soon as well.
I think I'll wait till after November. My last race is on the 5th and that's a good time to tear everything down and send the forks and shock off for servicing.
Thanks Les!
James
2016 Africa Twin
2019 RE 650INT
1982 KDX80
2017 KAW EX300
1982 XL500R
2015 HUSKY FE501S
1972 HON CB175
Old 07-20-2006, 07:41 AM
LTRace's Avatar
Thank you Mr. Barkeater, I really appreciate that.
Les
www.lt-racing.com
Old 07-20-2006, 08:45 AM
Eric K Eric K is offline
I will also add that Les does great work!
Les,
On my '06 EC300 the Ohlins shock HS comp adjuster only has 2.5 turns of total adjustment range. Did they make a change along the way or is there something wrong with my shock?
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 07-20-2006, 09:22 AM
LTRace's Avatar
Hello Eric,
Doesn't sound right to me, they typically have had about 4 turns of adjustment on this shock (give or take a little) I have not seen an 06 Gasser with only 2.5 turns of adjustment. It is certainly a possibility that a different internal assembly has been used by Ohlins on occasion, you may not be alone. There are allot of possibilities in their parts bins!
See if it performs correctly for your needs, run it in all the way and try it, you should notice a big difference on a sharp, fast hit. Open, it should be defeated and go through the travel easier. It may take several runs over the same terrain to really get a good feel for it.
Les
www.lt-racing.com
Old 08-26-2006, 06:30 AM
DaveJ DaveJ is offline
Originally Posted by LTRace
Hello Eric,
I just started fooling with the suspension and remember reading this the other day.
Pg 36 of the manual:
"High Compression Adjustment
To adjust, use a number 17 hex wrench. The control has 2.5 complete turns."
'06 GasGas EC300
FAQ; Suspension baseline settings LTRace Enduro Suspension 39 04-06-2019 06:51 AM
2005 baseline settings stay_upright Enduro Suspension 0 01-26-2009 08:37 AM
04 ec300 w/WP's, ESR valved. Settings? socalscott Enduro Suspension 0 04-28-2008 03:19 AM
baseline ohlins setting fullthrottle Enduro Suspension 5 04-26-2008 08:15 AM
Clicker settings for my 07 EC300? Cohunas Enduro Suspension 1 10-04-2007 07:37 AM
