Old 02-12-2015, 05:32 AM
bkwdc's Avatar
bkwdc bkwdc is offline
Mine measured 5mm side clearance before removal. Be sure and press in using the flat side of the bearing. Most are rounded on one side. I just use an appropriate sized socket and vise with a piece of wood on opposite side.
2011 EC300 Six Days
2010 EC300 Nambotin Replica
Old 02-12-2015, 08:30 AM
spooly's Avatar
spooly spooly is offline
5mm sounds like a lot? sure your o ring must be only 2 or 3 mm..I think 5 would be sufficient for standard seals like I used.. jeess I never took notice of the flat side to the baring ..I might re-press mine when im regressing. .
Old 11-09-2017, 04:19 PM
mrfreezer mrfreezer is offline
Guys.. I am going to overhaul linkage and swingarm bearing... I have found out, that I need 11x HK2216 and 1x HK1216 bearings and for seals o-rings 10pcs 21x3,5 and 2pcs 15x3,5... do you guys think bushings are good and I do not need to change them?? I can have all bearings and seals for 30,-?... If I would buy prox swingarm and linkage bearing kit with bushings it would cost 130,-? and as we know bearings in those kits are some chinese sh.t...
Old 11-09-2017, 04:26 PM
PEB PEB is offline
If the bearing are shot the bushings are very likely shot as well. Also be prepared to replace the bottom shock bearing and bushing as well.
Old 11-09-2017, 04:27 PM
It depends is the answer..
My experiences have shown the bearings tend to hold up really well if they have fresh grease periodically, in which case fresh grease again is all that's needed.
If the bearings have let go and you have binding, play etc, in most cases at least one bearing will have munched on the bushing and it becomes a replace the lot as a set experience.
I'd probably take the time to service the linkage, and depending on what you find then look at how you'll approach it.
Old 11-09-2017, 05:23 PM
PEB PEB is offline
I have two dogbone and linkage arm setups for sale if anyone would like to have a spare set around.
Old 11-10-2017, 06:16 AM
Zman's Avatar
Zman Zman is offline
I keep one in the spare parts box for each trip. A few of the kids in our riding group like play submarine every chance they get.
Thread Tools
Display Modes
Swingarm and Linkage Bearings blitz11 Enduro Chassis & Body 34 01-12-2015 03:41 PM
Synergyseals swingarm/linkage bush kit swazi_matt Enduro Product Reviews 10 03-25-2014 02:56 AM
Swingarm/Linkage-how does it go back together husley Enduro Chassis & Body 3 07-16-2011 10:36 AM
Swingarm linkage/bearing kits gasIdaho Enduro Suspension 1 02-03-2009 01:29 PM
