#21
I upped my shock spring to 5.4 for my pounds and sag needs but was advised to keep the front at stock (which I have).
#23
My guy said .48 in front and 6.2 rear for a 6'1. 235lb Fast B/Slow A. I'm only getting 18mm Free Sag and 106mm Rider Sag. So I really need a 6.3/6.4. To me, .48 and 6.4 is unbalanced. Should I bump up to .50 on fork when I install the 6.4? Or does the PFP allow me to get away with .48's?
Blanco Current ride: 2009 WR450 Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F Last edited by Bandit9; 12-21-2013 at 10:03 AM. |
#24
I have found I too like some preload from on the pfp. When I upgraded to .46 springs I set them up with 3mm preload and thought I would try 0 pfp. I seemed to lose stability and be more divey than the stock setup. So with more testing I ended up at .46 springs, 3 mm preload, 2 turns of pfp, c20 and r15. I ride terrain that is really rocky and hacked up but relatively smooth as far as bumps/whoops. If I would ride in sand with whoops I'm sure I would dial it a little different. I'll be doing more testing with increased pfp. The forks were quite good stock and I really have not quite happy and was really busy trying to get my KTM forks to work acceptably Last edited by celler; 12-21-2013 at 12:50 PM. Reason: Change Spring to .46 |
#25
Oz Current. 2015 ec300r estart, 98 RM 125 2013 Ec300r 2011 Ec300e 2009 Husky TE310 1982 XR500 Honda 1981 KE100 Kawasaki 1978 GT80 Yamaha |
#26
Reading old threads.
Revalved mine and looking forward to riding the setup. Always ran 2 turns in on the PFP, and with the changes immediately noticed a much firmer/precise front end. I made some pretty major changes in all the stacks though, and also tightened up the float from .65 to .4mm. I found the stock setup very plush, but also vaige and would kind of just wander in whichever direction they wanted. Didn't really deflect, or wallow too much, but found front tyre placement took more effort than I prefer. Now it feels sharp! So much so I think I may end up moving the forks through the triples a touch more as well. |
#27
What's your new stack.
#28
I won't post the complete ins and outs of it, and its only the first round of testing as well so could be quite a bit off.
Mid - kept the bleed shim, dropped the check plate design of the .15's and rebuilt a more tapered and traditional stack. Rebound - dropped the bleed shim, and used it as a crossover to make a 2 stage stack. Added in some more HSR. Base - again removed bleed shim and the randomness of the clunky thick shims and moved on to build a tapered 2 stage stack with a crossover for some small bump compliance. |
#29
Got it. I added a bleed shim to the Comp and removed one from the Rebound. No progression work done on the shim stack yet.
I have PFP all the way soft and the Comp clickers all the way soft and the Rebound all the way slow. Still not soft enough. It is a little firm on rocks and I think I detect a bit of a mid-stroke spike. . Rebound is near the ballpark but still needs more. I love how these forks won't bottom out on my usual cased mini jumps and G-outs. I definitely don't want to lose that feature. In the same boat with the shock. I will get it retuned in a week or three. |
#30
I'd love to get a little seat time on it before heading out for a big ride but I don't think I'll get the chance. Poor clearance under the bars to access the PFP and I haven't made any tools up so I'll be sticking with it at 2 turns initially. I'll give a more detailed report in a few days. I'm also using a 15.9cSt fluid.
Thread Tools | |
Display Modes | |
48mm zokes? | wence | Enduro Suspension | 5 | 04-30-2013 02:35 PM |
New Zokes | Fred1956 | Enduro Suspension | 2 | 12-05-2012 12:35 PM |
50mm zokes on an '05 EC 300? | siaknijustin | Enduro Suspension | 3 | 10-23-2012 11:24 PM |
Help with Rebound 11 Zokes | Tlineman | Enduro Suspension | 12 | 07-26-2011 04:34 PM |
48mm zokes | dublin | Enduro Suspension | 0 | 06-05-2011 05:34 PM |
