#41
The reason i put the 7.5 at 90mm is because when i originally bought the forks that is this viscosity and height i used. So i basically put everything back to original. The two teardowns after this i continued with the same. It was only when i started to get problems with lack of feeling and no adjustments that i tried a higher viscosity with a larger air gap.
1998 EC250 07 Shivers 2T racing PV Spacer FMF Gnarly |
#42
Hi daren where are you?, i need info i have the same problem and i want to know if your solution resolve the problem
GasGas EC 300 2004 |
#43
the forks has more rebound but also before but I changed many thinks try this rebound arrangement my Float only 1,0mm 15 x 0,1 15 x 0,2 15 x 0,3 15 x 0,3 18 x 0,1 22 x 0,15 Piston 22 x 0,1 22 x 0,1 19 x 0,1 19 x 0,1 17 x 0,1 17 x 0,1 15 x 0,1 13 x 0,1 rebound srew 12 cllicks open from full close a air gap of 110mm little bit to much for me on cross track
Husqvarna TE 300 |
#44
I am in England, My opinion is the new rebound piston rings have made a definite improvement. If you have the same symptoms as i had ( lack of feel, bouncy, no difference on adjustments ) i would change the rebound piston rings. Please note that other factors could also cause this but untill you strip down you will not know. If all is in order in your forks I would replace the piston rings. And then i would be inclined to look at some of Klausens posts and mirror his shim stacks, although you need to know what you want your bike to do, there are many changes you can make but they may not suit you, or your riding style. If anything you are in the right place to ask for help, I am a mere novice and there are much more experienced people in this forum who can make better judjments. Hope you get sorted.
Thread Tools | |
Display Modes | |
Damaged 45mm Shivers | Caravan Monster | Enduro Suspension | 2 | 08-07-2010 02:52 PM |
50mm shivers? | eddy field1 | Enduro Suspension | 2 | 07-31-2010 06:12 PM |
07 45mm Shivers binding | mike989 | Enduro Suspension | 10 | 05-14-2009 08:39 PM |
Marzocchi... Shivers? | jostby | Enduro Suspension | 1 | 05-12-2009 07:28 PM |
