#51
Glad you found a good solution. Are you using the 7.5 wt oil with this shim stack?
Barry 07 EC250 |
#52
you have to know that the SAE weight system has a very broad and vague viscosity range and does not even cover the viscosity range that most quality motorcycle suspension systems require.
look post #16 yes I use finally a 7,5 but this is a mix 1:1 Motul Expert SAE 5 and SAE 10 this viscosity is near the Marzocchi fork oil of 26,1 cSt@40C good luck my springs 4,5N/mm with 5mm preload
Husqvarna TE 300 |
#53
shims
hi klausen where can find the shims like you setup
best regards
GasGas EC 300 2004 |
#54
I believe you have different pistons and no mid valve only a check plate. A have a 2006 Shiver 45. A good dealer in Greece can sell you this shims. I can also offer you this shims. 1,80€ per shim is fair I think + P&P Bye
Husqvarna TE 300 |
#55
the forks feels to stiff at the end of the level what can I do? the fork use the full level (I use cable tie)
Husqvarna TE 300 |
#56
Are they bottoming out? Mine does it on MX tracks. I live with it because I like the way it works in the woods. Maybe decrease the check valve float??
#57
When I jump and land first with the rear wheel and the hard with the front wheel it feels very harsh. Quote:
Husqvarna TE 300 |
Thread Tools | |
Display Modes | |
Fork rebound question | Jeffro820 | Enduro Suspension | 8 | 02-08-2010 08:18 PM |
Rebound one side only? | chuz | Enduro Suspension | 0 | 09-20-2009 07:15 AM |
43mm WP rebound, help! | rupecopp | Enduro Suspension | 2 | 01-03-2009 11:01 PM |
Rebound shim recommendations (stiffer) | stay_upright | Enduro Suspension | 4 | 09-20-2008 02:20 PM |
Rebound adjustment on 04 & 05 MC and EC | FFRDave | Enduro Suspension | 4 | 01-23-2008 10:25 AM |
