Old 02-18-2013, 05:28 PM
Scar13 Scar13 is offline
Default What front shock on a 2010 ec250 2T??
Hi guys ,
What front shock Is on a2010 2t ec250 anodized Red ??? Also do I need anything special to change out the dust seals and fork sealswhich are leaking ???
Old 02-18-2013, 06:52 PM
They'll be 48mm Sachs forks.
Typical OC fork. Scary in them. You will need a 48mm seal driver to get the new seals in. The dust seals are TIGHT! you'll have fun getting them out.
ALSO! More than one of us on here has managed to cross thread the rebound clicker in the damper rod upon reassembly. Do a search for the correct method (basically take the clicker out of the cap first, thread it into the damper tube, then put the cap over the top).
KYB 48mm bushing and seal kit can be had for around $50 and includes everything that will fit perfectly! 09 CRF450R (from memory)
Old 02-18-2013, 10:50 PM
Fit synergyseals and you will only need to do it once!
2003 txt250 Pro
2013 Ossa 280i
Old 02-18-2013, 11:44 PM
twowheels's Avatar
Only once, but hide the women, children, and small animals while you're at it!
I might be tempted to go with SKFs on the first go round. Bushings are notoriously sloppy feeling when the forks are fully extended (bike on a crate).
Use a heat gun to relieve the seal groove before attempting to pull the oil seals, and do be careful on the rebound adjuster/rod removal and re-installation.
Steven Beane #275
afterhourscycle.com
Thread Tools
Display Modes
2010 Front Rotor crossover husley Enduro Chassis & Body 0 11-05-2011 11:53 AM
2005 öhlins shock fits 2010 EC300 bergerhag Enduro Suspension 17 10-26-2010 11:57 AM
2010 GG XC 300 Rear Shock Misprint? 2whlrcr Enduro Suspension 3 09-26-2010 11:20 PM
2010 Ohlins shock - rebound & revalve Keg Enduro Suspension 1 04-10-2010 04:43 PM
