Old 01-15-2015, 05:45 AM
Hulle Hulle is offline
Default Swingarm & Linkage Bearings
Hi!
Is there anyone that know where i can find the dimension of all the berings and bushing for the swingarm, linkage and lower shock?
I have a GasGas MC250 2003.
I would realy appreciate this, mine are total disaster.
Thanks in advance!
Gasgas 250 MC 2003
Old 01-15-2015, 09:19 AM
cbutler's Avatar
cbutler cbutler is offline
Allballs makes a complete kit.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 01-15-2015, 11:02 AM
Fred1956's Avatar
Fred1956 Fred1956 is offline
I've used AllBalls in the past & personally I think they are not the best bearing, they work & fit but I believe quality isn't the best, (may be Chinese made)
Pivot Works have been my choice as of late Swing arm kit is # PWSAK-G01-001 @ $69.95, linkage kit is #PWLK-G03-000 @ $89.95, Shock kit is #PWSHK-G01-001 @ $19.95. They also have wheel bearing kits as well as steering stem bearing kits for GG
I visited with the PW rep at a dealer show last year and- as long as you properly install a bearing they offer life time warranty on the kit. I have a customer who has claimed a warranty on a set of wheel bearing on a 2002 CR250 Honda, he had zero issues with them replacing the set. In my opinion as well as his the bearings didn't fail because of a poor bearing, he ran a nasty, muddy 80 mile enduro, they still replaced with no questions. If I remember correctly warranty is limited to 1 set per retail purchase but that makes them 1/2 price if you have to call the warranty. I know this doesn't answer the original but may be simpler than sourcing each bearing
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 01-15-2015, 11:54 AM
liv2day's Avatar
liv2day liv2day is offline
Gah...wish I would have seen this prior to ordering the linkage kit for my '11
Hulle - I don't know the cross-overs or if the information will apply, but it might be worth the time to read this thread: http://www.gasgasrider.org/forum/showthread.php?t=4452 Lots of information in there about the bearings.
Old 01-15-2015, 02:07 PM
Thanks for the information, i will take the berings out and let my local SKF dealer measure them, and then use o-ring as seals.
Gasgas 250 MC 2003
Old 01-16-2015, 12:43 PM
Rick's Avatar
Rick Rick is offline
I just completed a complete rebuild of my suspension linkage. I converted over to the "O" rings as well. Super easy, just make sure you clean out all the grease out of the area when the "o"ring is goes.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 01-16-2015, 03:39 PM
MNKeith MNKeith is offline
Post #4
http://www.gasgasrider.org/forum/sho...ngarm+bearings
-Keith
'08 EC250 and some other bikes.
Old 02-11-2015, 02:31 PM
5valve 5valve is offline
All balls and other sets are sourced from China and packed to look good. Therefore low quality. Tested.
Bushings should be tempered and honed to precise tolerance. Not in China case.
I too overhauled all rear suspension, but swingarm and linkage being OK, i just regreased and put together. Orings already there, so just replaced those with new.
I did take note of the swingarm bearings numbers, koyo, 28 x 22 x 16. Need 6 pcs.
Linkage bearings at least look the same, but not sure. (I think another 6 pcs needed)
Orings are the same for swingarm and linkage, ID22 x 3.5. You need a total of 10 pcs.
Shock needs upper spherical bearing 12 x 26 x 16, found in better local stores. Test it by keeping the shock bolted only in top, and try rocking it up/down.
Mine looked Ok, when I tried it with hand on the removed shock, but had play when shock was installed.
I can't help on the lower bearing, as I threw it away. Its a needle type, ID 16. Standard for sure.
If lower b. is toast, the bushing inside is toast also. Its 10 x 16 x 21. Not standard.
Managed to find 12 x 16 x 22. Ground off 1mm, to make it 21. Also the store had compensating bushings, so I press fitted two 10 x 12 x 10 inside. This made all work great. Zero play.
Old 02-11-2015, 05:03 PM
spooly's Avatar
spooly spooly is offline
What is the depth of the barings from the leading edge of the linkage? just for future reference .it a tapered edge as far as I remember. .
Old 02-12-2015, 01:19 AM
this is also a question i have asked, especially for the linkage parts that have two bearings and a gap between, never sure how much (if at all) the o-ring needs to protrude to make a proper seal without causing too much friction on the linkage
2003 txt250 Pro
2013 Ossa 280i
Thread Tools
Display Modes
Swingarm and Linkage Bearings blitz11 Enduro Chassis & Body 34 01-12-2015 03:41 PM
Synergyseals swingarm/linkage bush kit swazi_matt Enduro Product Reviews 10 03-25-2014 02:56 AM
Swingarm/Linkage-how does it go back together husley Enduro Chassis & Body 3 07-16-2011 10:36 AM
Swingarm linkage/bearing kits gasIdaho Enduro Suspension 1 02-03-2009 01:29 PM
