Old 04-21-2008, 08:42 PM
fullthrottle's Avatar
fullthrottle fullthrottle is offline
Default baseline ohlins setting
i am 65kg were is a good place to start for a baseline setting??
i currently have
hs=2 turns out
ls=15 turns out
rebound=30 turns out
sag 110mm
it still feels harsh sometimes and isnot sticking to the ground/tracking aswell as id like. im sure i dont have the best setting for my weight and am not a suspention tuner so dont know were to start thanks
06 EC250
Old 04-21-2008, 11:38 PM
widebear's Avatar
widebear widebear is offline
Banned
Stuff like this is pretty tough to do a virtual diagnosis on. But you might be a little light for that spring , provided that its the stocker that came on the bike.If its harsh and not staying planted I would try adding MORE comp and less rebound damping. Remember to do only one thing at a time.Good luck.
Old 04-22-2008, 09:48 AM
Loosenut's Avatar
Loosenut Loosenut is offline
Where is the shock harsh? Small trail junk, mid-size whoops, etc......
Do you bottom the shock?
I have had good luck with the following
I find a choppy section of trail on a hill. I adjust the shock full soft on compression and rebound. I ride the section of trail concentrating on the shock. I increase the compression 4 clicks stiffer and ride the hill. I repeat this until I notice the packing effect of the rebound being to slow. I back up 4 clicks and then start adjusting the HS compression. I keep adding 1/4 turn of compression until i notice the shock performance dropping. I back off 1/2 turn. The low speed compression requires big bumps to set properly. I pound through whoops, hit G-outs and such and figure out this setting. It's an easy adjustment on the trail, so I tend to adjust to the trails I'm riding. Big desert whoops require more low speed compression than my local riding areas. Anyway, once your in the ballpark, it fun to make small tweaks and see what happens. I softened my low speed compression on Sunday as the front end was biting too hard in the transition from hard pack to loam.
Hopefully you lean the feel of the adjustments and can make educated guesses as to what to do in the future.
Mike Baxter
2005 GasGas EC300 (Ohlins front and rear)
2007 Yamaha FZ1
2003 Pampera 280(hers)
Old 04-24-2008, 11:02 PM
it feels like its a bit harsh in the smaller stuff and in rocks i have just changed oil in my forks so i think thats why the shock is also behaving differently as forks seem a bit firmer. what do you have your rebound set at?? and the forks seem to bounce off rocks more now i have 110mm air gap in forks and i might try 120mm thankyou for ya help
06 EC250
Old 04-25-2008, 12:08 AM
bergerhag's Avatar
Are you running the stock springs?
They are likely to stiff for your weight. Browse through the Suspensions section, there are a lot of threads discussing spring ratios.
Old 04-26-2008, 08:15 AM
stock springs
06 EC250
Thread Tools
Display Modes
FAQ; Suspension baseline settings LTRace Enduro Suspension 39 04-06-2019 06:51 AM
Help with air screw setting on RB-carb joey11 Enduro Intake/Carburetion - 2 stroke 7 02-17-2009 07:09 AM
2005 baseline settings stay_upright Enduro Suspension 0 01-26-2009 08:37 AM
Setting up my EC300R 09 Keg General Discussions & Announcements 4 09-27-2008 07:42 AM
EC300 Baseline settings Magellan Enduro Suspension 7 08-26-2006 06:30 AM
