Old 03-03-2013, 08:12 PM
Thumbs up GGman KYB conversion
My previous bike had the 50mm 'zokes on it. (now enjoyed by Jay)
I really liked the lack of flex on them. My Current 45mm 'zokes just seemed to wallow in the ruts and deep sand.
I usually stay off the ground, last couple rides I've hit the dirt like 3 times. The front end would just loose traction and down I went.
So, decided to try the KYB conversion.
Thanks to EdVentura, GMP and Danj56 for their valuable input.
It was a LOT of work and well worth it. I rode today and the stock YZ valving seemed spot on. Front tire stuck like velcro. My confidence was very high. I did not get arm pump and my arms are not sore at all.
Here's my build. I found some brand new 2012 YZ 125 KYB forks on e-bay.
Parts used;
2012 YZ KYB SSS forks and guards.
2010 YZF 250 3x clamps.
2009 YZ 250 Front wheel w/ axle and spacers.
2010 YZ450 front caliper.
Replaced GG upper steering stem bearing with same one as the bottom.
Two door stops from HomeDepot.
I wanted to use the OEM GG fender and headlight. The YZF bottom clamp has two vertical pins that aren't used. So I cut threads on the pins to mount a bracket to hold the GG fender.
Bracket shown here. I drilled two new holes aft of the GG OEM rear holes.
For the fork stops, I installed some PopNuts in the frame to hold the door stops I bought from HomeDepot.
Door stops mounted. I have since shortened them to regain some steering angle.
Old 03-03-2013, 08:16 PM
Fork stop in action.
Top clamp install. I used the GG top bearing seal. The GG damper mounted up perfectly.
Headlight mounted up. Little far out on the bottom. Not bad though.
Side view. Front wheel did not hit the fender at all.
Old 03-03-2013, 08:32 PM
The fork compression is set at 11 clicks and the rebound is 6 clicks.
Now I have to get the shock to match the front forks.
Old 03-03-2013, 09:27 PM
jhendr3702's Avatar
looks like alot of work... glad it works great...
(and yes.. those 50's are sweet )
jay
pscook's Avatar
pscook pscook is offline
What did you do about the stem? Is the YZ stem close enough that you only replaced the upper bearing? Stem length is fine? If you don't mind, can you post up your total cost on parts?
Phil
(New bike pending...)
Old 03-03-2013, 09:34 PM
The stem is the YZF part.
The GG stem is smaller at the top and requires a smaller bearing.
The YZF stem is the same diameter for the entire length.
I'll add up the parts and let you know.
The brand new forks were $800 from e-bay. I bought new because I did not want someone's hack job.
e-bay seller has a crap load of new parts.
http://stores.ebay.com/328-Power-Spo...fsub=404612719
Old 03-03-2013, 10:28 PM
Rick's Avatar
Rick Rick is offline
What spring rate? OEM ? Do you plan swapping springs?
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 03-04-2013, 02:21 AM
twowheels's Avatar
Very sweet. Nice job.
Steven Beane #275
afterhourscycle.com
Old 03-04-2013, 10:08 AM
phoenix's Avatar
phoenix phoenix is offline
Very nice. Thank you for sharing. I love seeing people's ingenuity.
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
250 -300 conversion Stoby Enduro Engine - 2 stroke 6 03-07-2011 01:01 AM
GGMan & RGranger Boomhauer Pictures & Videos 12 03-03-2011 05:43 AM
250 to 300 Conversion Kurdt Enduro Engine - 2 stroke 10 03-30-2010 09:41 AM
ec 125 conversion? eddy field1 Enduro Chassis & Body 1 09-03-2009 09:00 PM
07 200 to 05 conversion brains Enduro Engine - 2 stroke 5 07-12-2009 12:54 AM
