#11
Thanks a lot. I have a similar fork coming my way now. I also found an unused one on ebay. However, I presume I will send them by the local suspension guru while I'm at it. I plan to use my oem wheels if its not too much truble, perhaps by cutting a suitable, smaller brake disk or fabricating a suitable caliper bracket.
Btw, the brake disk I use now is also a home brew. Sent from my OMNIA7 using Board Express
#12
So, are you available for hire I remember someone telling me that I should not work on my bikes anymore.....
Rob Granger / Katy, TX EC300 Breaking more things by 8:00AM than most people break all day. |
#13
Anything for you Rob.
#14
Not to hijack, but are you guys from the Houston area??? or maybe Amarillo?? I'm trying to find out what type of terrain to expect for the upcoming Nat Enduro
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
#15
I think Girard would welcome any excuse to avoid helping me work on the the bike We are in houston, Girad has ridden everywhere around here so he would be the best to answer - where is it being held? I have been so buried in work, I have only been able to keep one bike broken...
#16
which enduro.. i am in amarillo.........
broken down over 60 slow rider.. |
#17
The Concho, it's being held in Blackwell, Tx.
#18
have never rode there... but i think it will be alot of clay and rocks..
pretty rough terrain.
#19
So, I have a couple months of rides with the KYB conversion.
About 2 rides ago I installed some billet free pistons in the forks. Saw a lot of broken OEM free pistons on several forums. http://www.youtube.com/watch?v=D1tu98GQD3Y Flushed the fluid and bled the cartridges. I put 350cc of 5W fluid in the outer forks. That was too much. The initial fork travel was very plush, but harsh on the mid stroke. There were a lot of sharp spikes to my wrists. I called up SMART Performance and ordered their SPI 3 special fork fluid. http://smartperformanceinc.com/215VM2K5.html I added 300cc of the SPI 3 fluid to outer fork per their recommendation. The forks are very plush now. Even with the stock YZ125 fork valving/spring, the forks work really well. I don't think I have ever had this much confidence to go fast on the bike as I do now. We have a loop that we ride on, my average speed on the loop has been a steady 19mph. Today I hit 21.9mph. Helmet cam to come. |
#20
250 -300 conversion | Stoby | Enduro Engine - 2 stroke | 6 | 03-07-2011 01:01 AM |
GGMan & RGranger | Boomhauer | Pictures & Videos | 12 | 03-03-2011 05:43 AM |
250 to 300 Conversion | Kurdt | Enduro Engine - 2 stroke | 10 | 03-30-2010 09:41 AM |
ec 125 conversion? | eddy field1 | Enduro Chassis & Body | 1 | 09-03-2009 09:00 PM |
07 200 to 05 conversion | brains | Enduro Engine - 2 stroke | 5 | 07-12-2009 12:54 AM |
