Old 07-08-2014, 08:12 AM
Eric K Eric K is offline
I put a set of '07 YZ450 forks on my '06 EC300. Stock valving and springs as far as I can tell. I cleaned them out, put in new oil and new fork seals.
The YZ forks are light years ahead of the 45mm Zokes. They are way more stable and track straight where I point the front wheel. The YZ forks work much better at any speed, under any condition, from riding rocks on 4x4 rock crawl courses to skipping across the tops of whoops. They absorb whoops and huge trail chop without any complaints or front end deflection. They rock!
This is what I did...
Installed Yamaha 2007 YZ450F 48mm forks and 2009 YZ450F triple clamps. The later year triple clamps (around 2009) had 2 bar mount positions. Please note that around 2010 Yamaha changed the upper fork tube outside diameter so you need to check on triple clamp & fork compatibility if you match from different years.
I welded on a steering rotation stop from a 1985 CR500 frame that was lying around. I left the old bearing race in when welding. However, it still distorted the bearing race housing in the frame that required some die grinder work to open up.
I used Bearing Connections steering head bearings for a 2009 YZ450.
I used the 2006 stock GasGas wheel and brake rotor. This required...
1) Installation of the smaller bearings. I used a Moose bearing set for a 2001 GasGas front wheel.
2) Install front brake Braking bracket POW13.
3) 2006 YZ250F axle
I also needed a YZ front fender.
These forks have spoiled me. It was well worth the cost and effort.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 07-08-2014, 02:22 PM
hi Eric thanks for your input mate ill start looking out for the bit and build it up, the bike is a bloody good bike old or new. its just the zokes that let it down
03 ec300
honda cr500 94
Old 07-08-2014, 02:25 PM
what about wheel spindle did you use eric
03 ec300
honda cr500 94
Old 07-08-2014, 03:35 PM
iamovru's Avatar
iamovru iamovru is offline
Originally Posted by Jacob 'Berg View Post
+1 Get them tuned. My zoke 45's perform as well if not better than the WP forks on my Husaberg and the berg is 3 years newer.
+2 Mine are also pretty good
15 Beta 300RR Race
Sold KTM 450EXC now moving over to RED! Looks like I found the right bike. Thanks REVERUP!
2011 GasGas EC300 "Stolen By A Scum Bag"
2009 450EXC Sold to Rapid Dog EURO Factory Anti-Hop slipper clutch, GPR V4, Akropovic Full Ti Exhaust, 2013 suspension and wheels.
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Old 07-08-2014, 11:00 PM
2006 YZ250F axle
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 07-08-2014, 11:02 PM
djroggen's Avatar
djroggen djroggen is offline
Default what forks to use
I sent my forks to Drew Smith WER in PA and he turned my 45 Zokes into some very good forks. Very good in the rocks and roots still to be desired on an mx track.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 08-13-2014, 07:53 PM
Well I've taken the plunge & bought a set of local '06 YZ250 sss forks, axle & triples. I'm probably going to try mod the triples to get steering rotation stops but we'll see. Biggest thing to do first is machine up a caliper mount as I'm too cheap (out of funds) to buy the braking one.
Thanks for the ideas esp Eric.
Old 08-13-2014, 09:33 PM
nknudsen's Avatar
nknudsen nknudsen is offline
On my 08' SSS forks (different caliper mount than your 06) I used / modified the oe GG caliper mount. One mounting hole lined up and I just welded one mounting hole shut and drilled and tapped a new one. Just get crafty if you need to. I did shim it out from the forks with a couple shim washers to center it on the disc.
Noah
16' Specialized Fatboy trail
02' ZRX 1200r R.I.P.
15' TW200
Old 08-13-2014, 11:12 PM
Elvis74 Elvis74 is offline
Every caliper mount for Yamaha for over sized discs (260mm) fits!
Old 08-14-2014, 12:52 AM
Cool, yeah I'd read that post during my research. I've done a few brackets for road & roadrace bikes so I'm not that scared of it, but I could do without $80 & shipping added onto the conversion cost. Better spent on bearings for which I'll need steering & smaller ID front wheel by the looks.
I usually dummy up plates in plywood to get the holes aligned & then transpose to allly.
Which used forks do I have? wmcpb04 Enduro Suspension 17 06-11-2013 07:59 PM
forks robicon Enduro Suspension 2 05-08-2012 02:42 PM
43 mm wp forks. jhendr3702 Enduro Suspension 4 10-18-2010 06:46 PM
forks sen480 General Discussions & Announcements 1 03-25-2010 04:54 AM
