Old 09-05-2014, 03:16 AM
ypm25 ypm25 is offline
Default 06 EC200 Set up for short rider
Hi I have just got a 06 EC200 and looking to lower it. My old KTM I cut the seat up and that was 'just' about right.
The GasGas has a linkage and there seems to be some lowering kits around. My question is.. Should I mess with the geometry if I can get away with cutting the seat down.. ? Are there any issues with using lowering kits ?
I'l be using the bike for Enduro H&Hounds.
Thanks
Old 09-05-2014, 06:46 AM
I have trimmed the seats on a couple bikes and that should not impact handling. To get them shorter, I used the 124mm (longer) linkage bars, which lowers the rear of the bike about an inch. Depending on your handlebar standoffs, you can also drop the forks in the triple clamp a bit to drop the front end.
Old 09-05-2014, 09:01 AM
Caravan Monster's Avatar
Guessing you're in the UK ? I have some second hand 125mm (centre to centre) lowering links I can sell. Never needed to lower a bike for myself, but would expect having a suspension tuner shorten forks and shock would be more succesful because just lowering the back end would mess up the fork angle.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 09-05-2014, 12:51 PM
I agree, when you drop the rear you should also lower the front a corresponding amount to keep the bike level. That is why I mentioned the handlebar height to allow for room to move the forks in the triple clamps.
Old 09-08-2014, 08:10 AM
Thanks allot, yes I'm in the UK I would be interested in the lowering links.
I will cut the seat first and see how it is.
Old 09-08-2014, 11:34 PM
You can also get a cobbler to add a 2nd sole to your boots.
I'm 5'8 & not long legs, I just have the forks dropped as much as poss & at the lower end of the preload on the rear & I'm fine. I made the mistake on my last bike of cutting the foam down too much. Was ok till I got used to the bike then it was too low so made standing up harder.
Short riders! Adss General Discussions & Announcements 18 03-11-2014 12:30 AM
How about short riders on '12 adv rider General Discussions & Announcements 18 12-03-2013 07:25 AM
Just a short ride vid. Metalefty Pictures & Videos 0 11-30-2012 09:17 PM
short bar risers..... jhendr3702 Enduro Chassis & Body 2 01-10-2011 12:29 PM
Short 2010 250 Six Day review Skidad Ride Reports 3 03-05-2010 10:42 PM
