"Wanted to Buy" & "Want To Trade" Bikes or Parts |
Wanted 450 fse starter clutch see picture
Attachment 7332Hi if anyone has starter clutch they would like to sell , or if anyone could tell me if it is left hand or right hand thread , and what is in the middle of the two parts that would be a help.
This is for a 2004 450 fse . I am located in the U.K. Last edited by Stu1; 03-03-2018 at 11:59 AM. |
Thanks for that , at least I now know what it is called .
I don?t suppose you know it it?s a left or right hand thread. |
I am pretty sure it is a rh thread, as I don?t have a torque wrench that does lh threads.. but it was 04-05 when I was last playing on them!
I have replaced the sprag clutch , if I can fix this I can get the bike running. |
From the top of my head they had what looked like big dished spring washers, the nut could be tightened to give more or less slip, they were updated a fair few times from the factory till they changed design in '06 IIRC. The starting systems were never great on the gasser 4t's, when coupled with the early magnetti marelli ignition systems they were lucky to start. Even new. They got a lot better with the '09's that had the japanese kokusan ignition systems.
Many thanks for that information , at least I may be able to bodge it up somehow, providing I can undo the bolt .
That?s if I don?t have any luck sourcing a replacement . |
WANTED. 450 fse 2004 starter motor | Lambretta man | "Wanted to Buy" & "Want To Trade" | 0 | 12-09-2017 05:36 PM |
wanted.... starter motor for gas gas quad | richy5118 | "Wanted to Buy" & "Want To Trade" | 0 | 12-21-2015 06:40 AM |
Starter clutch / gear problem | iancp5 | Enduro Engine 4 stroke (including EFI & Exhaust) | 12 | 01-28-2011 02:45 PM |
2002 ec400fse starter clutch | jason r | Enduro Engine 4 stroke (including EFI & Exhaust) | 6 | 09-09-2009 04:47 PM |
