Old 11-10-2020, 08:05 AM
Anders Anders is offline
Originally Posted by Beastie Boy View Post
Definitely thread revival time.
its time to repalce the stock tires on my 19 EC300
Looking for recommendations
90% single track / slow technical
Hardly ever any mud!
Under those circumstances I would suggest Mitas C19/C18 Superlight (green stripe). These are my favorite tires for technical riding. I have run these Mitas tires tubeless, using T-Lock (a competitor to Tubliss), without any problems for years. I run them with quite low pressure. However, Mitas reccomends using mousses as the Superlight side walls are pretty thin.
My daughter also uses these tires (with tubes) on her RM125 in the woods.
Old 11-10-2020, 09:52 AM
dANbOT's Avatar
dANbOT dANbOT is offline
I like this topic, so I'll throw a couple in:
Tire- Shinko Cheater 505 rear
Pressure the tire was run at- 5-7psi
Inflation device - tube
Terrain ridden- tight, steep mountain single track
How well did it work- Excellent
How well the tyre lasted- Amazing
Any other notes- Only shortfall is mud/soft ground traction.
This tire grabs rocks, logs, and anything but the softest ground or mud very well. The bonus is it retains good traction into significant wear (which takes a long time, tire wear is very slow)
Bike (model and year)- 2014 EC300
Skill level- Advanced
Location- Western Canada
Would you buy another? Yes
Tire- Mitas XT754 super light green stripe rear
How well the tyre lasted- Average
Any other notes- This tire is amazing for softer / mud conditions. It works good as an all around single track tire, but has a tendency to spin on logs, roots, and very hard dirt.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 11-11-2020, 09:00 PM
farmerj's Avatar
farmerj farmerj is offline
Goldentyre Fatty front and Kenda Ibex rear, you can't go wrong.
I admit I have yet to run the Ibex- but it comes highly recommended in your application. That and the IRC VE33S Gekotta (gummy) are on my "next to try" list.
Tires I have used:
Kenda Equilibrium - Very good traction, very good tire, but can feel "wallowy" at speed. Not good in mud, as it doesn't clean out well. But I don't like riding in mud anyway! This is a big tire (which I like).
Goldentyre GT216x - Great traction, a smallish tire. No complaints.
Shinko 505 - Hooked up great in a straight line, not great in mud.
I found that it slipped sideways on roots - but note this! - I may have been running too low of a pressure. If you do not run enough pressure in a gummy tire, the knobs actually "fold under" I am told (picture the center of the tire carcass pushed up toward the middle of the rim). When this happens, the tire slides/slips. So I do not think my experience is a common one.
The new Shinko 520DC sounds interesting.
Goldentyre GT333 - One of the best all-around tires made IMO. It is not gummy, but has excellent grip because of the soft carcass that flexes around objects. It's tough - I've run it in woods, rocks, desert, mud, snow - it works everywhere and works well. I had to lengthen my chain to keep it away from the mudflap. Wears well, too, in that it works even when the knobs start to get shorter.
Goldentyre Fatty on the front - great tire, I can't bring myself to run anything else!
Just IMO,
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 11-14-2020, 01:45 PM
B737 B737 is offline
South of Europe, WESS land - single track slow technical hill climbs, rivers, rocks, roots etc.
Summer ? loose rocks - tubliss front and back
Mitas C18 yellow/green @ 0.3/0.5 BAR + GT216aa (90/100) @ 0.7 BAR
Winter ? wet/slippery - soft mousse front and back
Mitas EF07 1 or 2 green (140/80) + Mitas C19 green (90/90)
That?s my go to
Old 11-15-2020, 03:52 AM
Beastie Boy's Avatar
Beastie Boy Beastie Boy is offline
Great replies ....thanks!
2019 EC 300
Old 03-09-2021, 04:23 AM
Finally went for :
Shinko 505 120/100/18 rear
Shinko MX216 90/100/21 front
Did my usual intenet searches and chose the tyres i could get easliy with ther least number of bad reports
Never ridden with a gummy or a fatty(tyre!) before....so should be interesting
2019 EC 300
Old 03-09-2021, 09:45 AM
Bryan's Avatar
Bryan Bryan is online now
I was running Michelin S12 front and rear. Good tire, but the new generation of "gummy" tires are simply amazing.
Rear: Kenda K787 Equilibrium 4.50 x 18 6 ply ($80.61) @ 5-7 psi
Front: Goldentyre Fatty 90/100-21 ($99.95) @ 5-7 psi
I run heavy duty tubes. Terrain is tight single track, steep ups and downs, logging roads, etc.
I have ridden about 100 miles so far on these tires. They look like I just put them on still. They are wearing very well. The traction is a huge leap forward from the Michelin S12
Both tires have very stiff sidewalls and very flexible center treads which allows the tire conform to the terrain. They are amazing in the roots, rocks, mud you name it. It didn't matter if it was really wet or hardpacked dry. Could do 60 on a logging road no wondering around with the low pressures. Never even came close to hitting the rim on rocks.
Just unbelievable difference in tires. If you have not tried the new gummy tires, you owe to yourself to do so.
07 EC 300
06 Gold Wing
(2) 06 CRF 150 F
Old 07-26-2021, 12:17 AM
So far have done one ride with the Shinko 505 / Fatty combination.
First impressions , really positive reaction to the front. As everyone says it doesn't deflect as much , more stable and better for tech riding
It was only one ride of about 4 hours but did not notice any major negatives to the handling from the front
I did notice the increased height of the front but it did not affect the handling and didn't bother me.
I noticed no real difference from the rear . The conditions were very muddy (rarely ride in these sort of conditions) so not the type of conditions I would expect to see big advantages from a gummy. But no negatives either in the muddy conditions so all good!
2019 EC 300
Looking for information to split case RayGas Enduro Engine - 2 stroke 2 05-26-2008 08:15 PM
Tire stand for moose or tire balls kim Enduro Other... 6 12-28-2007 12:12 AM
Information please NewB GasGas Member Polls 3 10-25-2007 09:36 PM
2007 Model Information jeffd General Discussions & Announcements 8 08-27-2006 01:52 PM
FAQ Information Needed.... webmaster General Discussions & Announcements 0 08-02-2006 11:28 AM
