2002 EC300 swingarm rubbing block replacement options?
Newbie here, bought a 2002 EC300 a while back and haven't done anything but ride it around the yard yet, but yesterday I inventoried all the things I need to do to "dial it in" before the first real ride.
I noticed the chain rubbing block on top of the swingarm at the front (pivot) end was missing, just a broken piece of rubber at the single attach screw on the top side. I ASSUME this rubbing block wrapped around the front of the swingarm and also attached underneath. Haven't researched OEM replacement sources yet, is this also available as an aftermarket part? Where? |
TM designs do one. Just fit one and It's as std
will '21-'23 fit an '02?
I found this one @ TM Designworks, wondering how far off (if any) this is from fitting my '02?
https://www.tmdesignworks.com/p-2960...n-dcs-kt3.aspx |
And do you have to remove the swingarm to install it?
This is the one you need you must pick Rieju(GasGas)
https://www.tmdesignworks.com/p-145-...n-dcs-ggm.aspx Yes it can be changed without removing the swingarm just remove chain and sprocket.
Gas Gas light switch block replacement. | n_green | Enduro Electrical & Wiring | 6 | 01-28-2018 01:59 PM |
2012 EC300 swingarm rubbing rear master cyl | scorpa1 | Enduro Chassis & Body | 4 | 03-24-2014 10:13 PM |
rear master cyl rubbing on swingarm? | davermb | Enduro Chassis & Body | 5 | 07-02-2012 08:16 PM |
Master Cylinder rubbing on swingarm | Malcolm | Enduro Chassis & Body | 1 | 12-13-2009 12:36 PM |
Stand Rubbing on Swingarm | coolum74 | Enduro Chassis & Body | 14 | 06-16-2009 11:31 AM |
