Old 02-08-2024, 07:52 AM
NHtrailrider NHtrailrider is offline
Default 2005 EC200 Small End Bearing
Doing a top end service on my 2005 Gas Gas EC200. Replating the Cylinder and new Wossner Piston. Wossner states the small end bearing to be different from that of an EC250/300. The dimensions of the bearings are different with the EC200 bearing being 2mm shorter (19.8mm vs 21.8mm).
The history of the bike is unknown, but I found a wossner A size piston and 21.8mm small end bearing previously installed.
EC200 P/N: N1020
EC250/300 P/N: N1021
Does have any experience rebuilding an EC200 and can confirm which small end bearing I need. I have purchased the shorter one and it fits inside the crank just fine, however it is flush with outsides of he small end crank opening. The longer bearing will overhand the small end crank opening by 1mm on each side. Does this matter?
Old 02-09-2024, 01:43 AM
(F5) (F5) is online now
Not for a very long time.
But do consider the piston and how much it may limit bearing sideways travel.
some are quite angled top to bottom.
Old 02-09-2024, 02:36 AM
Anders Anders is offline
I am about to rebuild my 2015 EC200's top end quite soon. I have all the parts waiting for me in the workshop. I can pop out tonight and measure the bearing.
Old 02-11-2024, 06:52 AM
I could't find the bearing, but I checked the 2015 parts list. There, the 200 and 250 share the same part number.
Need confirmation please! EC200 small end bearing Stephan Enduro Engine - 2 stroke 2 08-29-2023 03:29 PM
2005 Gas Gas EC200 Rien Deau Used Bikes 0 05-07-2017 07:38 PM
GasGas 125SM 04 Small end bearing Nicke_pota Enduro Engine - 2 stroke 1 05-04-2017 12:10 PM
2001 ec200 Rod Bearing Kit mattholew Enduro Engine - 2 stroke 12 01-19-2016 05:26 PM
2004 EC200 Gas Tank Looks Small Zman Enduro Chassis & Body 14 09-17-2014 04:43 AM
