Old 12-07-2006, 11:32 AM
Dingoe Dingoe is offline
Default Bearing kit cross???
Does anyone know what swing arm and linkage bearing kits cross with the Gas Gas 2s.
Mine looks old dry and a bit pitted, but I'll sand clean and repack and hope to get by. If I need them I'd like to get full kits at a good price. I'm runnning out of funds working on the bike.
thanks
Old 12-11-2006, 04:21 PM
wheels7 wheels7 is offline
Default linkage and swingarm kit
moose racing has a kit for the gas gas bikes i have my kit for my 300 i just need to put it in. but i cant figure out how to get the swingarm bolt out?
Old 12-11-2006, 05:57 PM
http://cgi.ebay.com/ebaymotors/REAR-...62669801QQrdZ1
there you go
Old 12-12-2006, 03:06 PM
Thanks for the info, on the swingarm bolt, I pulled my linkage and arm from the frame with the help of WD-40 and MR. Hammer. Water did a number on it, but it's out and it's clean now. Get a long 3/8" extention and drive it out, make sure the right side is free of rust, dirt , etc.
Old 12-14-2006, 10:23 PM
Boomhauer's Avatar
Boomhauer Boomhauer is offline
Leave the nut on the end of the bolt and un thread it so slightly and use a punch and a hammer. GENTLY tap on the nut until the bolt starts to move and repeat the process.
The nut is on the driver side (left side) of the bike. The bolt will then push out thru the right side.
Also when I put mine back together I always fill the swing arm bolt cavities with grease to keep out dirt and water. I have had no problems doing this.
Good Luck!
Bikeless for Now
Thanks to Smith's Powersports 724-899-3375
www.smithspowersports.com
Air Filter Cross Over ?'s lordfeyr Enduro Intake/Carburetion - 2 stroke 11 02-25-2011 11:00 AM
Big End Bearing twistywizard Enduro Engine - 2 stroke 15 01-26-2011 06:33 PM
reeds cross-over? moff747 Enduro Intake/Carburetion - 2 stroke 4 05-25-2010 02:32 AM
Wrist Pin Bearing SpeedyManiac Enduro Engine - 2 stroke 16 10-08-2009 09:37 PM
lower shock bearing cross-ref? fasternat Enduro Suspension 1 02-21-2007 10:20 AM
