lower shock bearing cross-ref?
Hey, All,
My 01 xc 200 has a bad bearing. The lower shock mount position on the funky pivot thing bearing was rusted. I cleaned it up as best I could and regreased it but I know I gotta replace it. Does anyone know if I can buy just that bearing? The rest are still good. If I knew of a stock # maybe I could look for it. thanks, NAT
fasternat |
Nat,
Check with the guys over at GoFasters they will have what you need. www.gofasters.com or call them @ 1-877-363-8767. "Funky pivot thing bearing" I'm assuming you are talking about your lower shock bearing on the bottom of the rear shock where it attaches to your linkage since that bearing wears faster than the others. Good luck with it. Also there is a sleeve or bushing that slides into the bearing that your bolts goes through get one of those as well since those will wear once the bearing goes. |
washers on lower rear shock? | lineman12345678 | Enduro Suspension | 19 | 06-20-2014 04:35 PM |
lower end question | mxdj2003 | Enduro Engine - 2 stroke | 0 | 09-08-2009 05:25 PM |
Bearing kit cross??? | Dingoe | Enduro Suspension | 4 | 12-14-2006 10:23 PM |
Lower End Rebuild | PEB | Enduro Engine - 2 stroke | 1 | 10-06-2006 06:36 PM |
