Old 07-12-2011, 11:03 PM
rgranger's Avatar
rgranger rgranger is offline
+100 on GMP and spring numbers. I dropped the KTM two sizes and it is simply fantastic now and still doesn't bottom. I went down one size from speck for my weight and what Les had setup, again another big woods improvement. After looking around, I think most of the numbers are based on MX and jumps. Both my bikes really kicked the back end around in the woods and over roots, softening it up allowed the suspension to do what it is designed to do, absorb shocks! Maybe I am more forward when riding, standing or seated, but it took me from a plodder to keeping up with a B rider...overnight, yeah really!
Play around with that stuff. It moves and is adjustable for a reason
Rob Granger / Katy, TX EC300
Old 07-13-2011, 08:33 AM
The main thing is the preload and the begining of shock/wheel travel, how easy it is for the wheel to respond to small hits, and how fast the wheel is rebounding from those hits. This has the most effect on how the bike sucks up trail trash. If your spring is too light steering may suffer, and jacking the preload to correct it is the whole point of this thread. Keep in mind that the basic shock valving must be sound for your spring/weight/speed/terrain so you don't attempt to over compensate somewhee else. I'm running.44/5.4 combo and I'm 190 lbs. 1mm preload on the fork springs, around 9-9.5mm on the shock. Compression adjusted to as much as possible before harshness. I can soft bottom the bike on some fast whoops, but I don't ride that stuff much. When I do a little more comp F&R takes care of it. We don't have a lot of deep whoops and big rocks in the same area here, its one or the other. The bike eats rocks for lunch, not with a mushy couch type ride at low speeds only, but with a firm controlled feedback and no deflection that allows good speed and stability.
Another thing. Don't soften up the fork in an attempt to get rid of the harsh mid spike in certain conditions. This will pitch the bike foward and make the shock feel worse. Solve the real problem (rebound) discussed in the other thread, and things will start falling into place nicely.
Old 10-04-2011, 01:38 PM
stainlesscycle's Avatar
how are you setting preload on the sachs - since it's already preloaded a few mm just to get the spring on? just set approx 10mm preload from fully out?
07 ec300
www.stainlesscycle.com
Old 10-04-2011, 08:40 PM
My spring is about zero preload mounted with the rings backed off. I'd work with the actual spring length as a reference.
Old 10-05-2011, 12:07 AM
If you use a spring off a Husky Sachs they are a little shorter. I used a GasGas Sachs spring on my Husky and it had a little preload backed off all the way like you mentioned. I started at 10mm and ended up backing it off about 2mm. I just rode the bike and adjusted it little by little until I liked it.
BTW I was using a 5.6 spring.
Old 10-05-2011, 08:27 AM
Yes, I have a 5.4 Sachs spring from a Husky WR250. I have to lean on the lower ring to get it on and around the shock shaft, but once on its just about no preload. Lanky basically found the sweet spot by feel which seems to work out less than 10mm. The rear calms down nicely. This a trial and error thing, takes a little time on the same trail/obstacles to dial in.
Old 10-05-2011, 08:16 PM
I used two cheapo tie downs with no hook on one end, just a loop strap. Ratchet them down equally on both sides of the spring at the 2nd coil from the end. It's a poor boy spring compressor.
I rode my bike through some hard 3rd gear whoops and set the preload and the clickers so the front and rear balances out with the front slightly nose up so it doesn't dive in whoops but will still dive on the brakes so I can turn. I set the rebound dampening so I don't get kicked in the butt on braking bumps. After I did that the rest kind of fell in to place.
There may be a better way to go about it but this seemed common sense to me and it worked.
Old 06-01-2012, 09:16 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
i am going to redo the shock preload on the 12 Glenn.
This should still be similar or is the ohlins a different kettle of fish?
I know that currently my shock is way to compressed( too much preload), and I probably need the next spring rate up.The bike is very jarring and seesaw like to ride which I am putting down to the overcompressed shock spring.
I am going to try the 10-12 mm trick and see what goes.
Cheers Mark
Xr 250 ( first bike)
98 Rmx
2008 280 Raga replica
2012 Gas gas ec 300 E
Old 06-01-2012, 12:12 PM
I think its a general thing that applies to most bikes. The preload should be < 10mm but there is no substitute for the correct spring(s). Try it and see, did the shock come with the preload all cranked up? I'm hoping I can get away with the stock springs and save a few $$, weighed in at under 180 yesterday.
Old 06-01-2012, 12:37 PM
i think it's time for me to get a spring - 5.4 is just not cutting it - i'm close to 20mm preload to make it sit right.. my weight with gear is 210 - i tried 10mm preload but can't get the sag even close...
07 ec300
washers on lower rear shock? lineman12345678 Enduro Suspension 19 06-20-2014 04:35 PM
Rear Shock Spring--Where Am I? Where Do I Go? smstewart Enduro Suspension 0 04-19-2010 05:35 PM
07 ec250 will 05 ohlins rear shock fit gasgasandrew Enduro Suspension 1 01-22-2010 04:39 PM
Removing Rear Shock gasIdaho Enduro Suspension 12 02-04-2009 10:45 AM
rear shock sag under bikes own weight rupecopp Enduro Suspension 7 12-18-2007 08:06 PM
