Old 09-06-2015, 12:09 AM
fullthrottle's Avatar
fullthrottle fullthrottle is offline
Managed to pick up a complete front end off a 2006 yz450f for $250 including wheel brake m/c plastics t/clamps.
Just to confirm if I change the bottom head stem bearing and get a steering stop sorted I can fit the complete front end??
Forks will be revalved and new springs, what spring rate should I look at? Im 70kg no gear.
What is the measurements of the bearing I need?
Where will this leave me in terms of fork/axle offset compared to stock?
Thanks for any help
06 EC250
Old 09-07-2015, 05:47 AM
I haven't done a full front end swap, so can't comment 100% what's involved.
I can point you to this thread though!
http://www.gasgasrider.org/forum/showthread.php?t=14592
and this one too. http://www.gasgasrider.org/forum/sho...t=12745&page=3
You'd have to check the offsets for that particular Yamaha model. The GG uses a 22mm triple, and 35mm lug offset if I recall correctly. YZ 2T uses 25mm triple and 32mm lug, so same same. I reduced total offset by 3mm with my fitment, and notice the difference in terms of force required to steer the bike, but don't find it bad at all (but that's on a 13 chassis too).
Old 11-18-2016, 11:00 PM
_Hammy _Hammy is offline
I thought that I'd tack this onto Jakobi's thread since he's mentioned the WR's in his original post
I'm looking at a set of KYB forks off an 08 or 09 WR450F
Does anyone have any opinions on whether these are worth the effort to swap with the sach's on my 09 ec300, or should I hold out longer (and more $) for a SSS set?
My intention is to use the gasser triples and front wheel (as it's set up with a tubliss system) and the WR axle, a braking brake caliper mount etc...
I've gotten myself confused with the various fork options, so some clarity would be appreciated
I'm not fast by any means, and the bike will be set up for technical bush/woods riding, but I also want it to be capable over woops, braking bumps/trail trash and not too soft for casual club MX
The other issue is that my top triple clamps are for 54mm OD forks, whereas the WRF's are apparently 55.5mm OD. I've had varying opinions on whether I "could" get them into my clamps, and whether I "should" do it given that it'll put some pressure on the tubes
Old 11-18-2016, 11:32 PM
pscook's Avatar
pscook pscook is offline
Don't force them, that would be bad. You could easily have someone bore them to match, I would think. Only 0.75mm off the clamp, shouldn't cause too much grief.
Phil
(New bike pending...)
Old 11-19-2016, 12:09 AM
That'll be my plan I think if they don't fit. There looks to be plenty of material on the clamps so it shouldn't weaken them. I prefer this over swapping out the triples completely for the WRF ones, and then trying to sort out a steering stop
Old 11-21-2016, 06:24 AM
Can any one tell me if when I measure the trail at the front axle, whether i measure from the axle centreline back to the centre of the fork leg , PERPENDICULAR to the fork leg, or PARALLEL to the ground?
Old 10-08-2018, 01:58 PM
(F5)'s Avatar
(F5) (F5) is offline
Good idea F5. We'll bounce this idea more when I get to it.
Forks should be arriving next week some time.
I have an axle from an 04 WR250F at my disposal (including front wheel and spacer). I was thinking I may be able to transfer the whole lot across, but thinking things through I will meet issues as the WRs use a 25mm offset lug so the brake carrier will still be out.
Working off this, I've found a better list of various KYB SSS forks and their dimensions.
YZ250F (02-06) 35mm lug / 56mm upper clamp.
YZ250F (07-11) 32mm lug / 56mm upper clamp.
YZ250F (12+) 32mm lug / 54mm upper clamp (fits stock 48mm triples).
YZ450F (03-07) 35mm lug / 56mm upper clamp.
YZ450F (08-09) 32mm lug / 56mm upper clamp.
YZ450F (10+) 32mm lug / 54mm upper (fits stock 48mm triples).
YZ250 (01-07) 35mm lug / Believe all use 56mm upper clamp.
YZ250 (08+) 32mm lug / Believe all use 56mm upper clamp.
WR250F and WR450F (02-13) 35mm lug - unsure which years inc SSS vs OC. Believe all use the 56mm upper clamping diameter.
So from that list, depending on what you want to achieve and whats available will depend whats required.
I intend on using the Stock Gas Gas 22mm offset triple clamps with the 12 YZ250F forks. The reduction in overall offset will be -3mm. If using forks with the larger upper OD, using KYB 25mm triple clamps will retain the stock geometry/overall offset.
Also, as I plan on using the Gas Gas front wheel which has a 260mm disc vs the YZF 250mm I will require an oversize caliper carrier for the particular forks (lug offset) that I will be using. Braking POW106. I have ordered one of these.
For the forks with the 35mm lugs the correct carrier is POW13.
The ideal solution IMO would be to source a set with 35mm lug from a late model WRF and have the upper triple clamped machined - I'm taking a risk with the -3mm offset for the ease of fitment. If the reduced offset ends up being too much I will be somewhat limited in my options as these late model Yamahas they come off all use 20mm offset triple clamps. I could source some older triples and shim the upper clamp. In my research I have read that many people would however sub out the stock 25mm offfset clamps for 22/22.5mm on the YZ250's for better handling.. I have also found the head stem angle to be similar between the 2 bikes, and that most new bikes run a similar angle with less offset. Glenn found the increased trail to be too much on his Beta 2T, however they already come standard with a 20mm offset clamp. Both bikes use a 27 degree steering rake angle.
Ok so I'm going in again, this time a mate's 2010 his marzocs are eating seals. It will fall on me to do everything so I want the laziest solution but still give him good forks, he loves mine.
He measured his forks and got 59mm lower clamp 56mm upper. Just like my 2006 YZ250 forks. Your chart indicated they should be 54mm. Should I go measure to be sure?
YZF450 seem most common over here for spares. The -3 lug if we go 08,09, Should be ok on the 10 do we now think? Do we need WR axle or mod YZF?
Cheers.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 10-08-2018, 03:51 PM
Cheers.
I wouldn't decrease offset at all on the 2011 and earlier chassis. The change was noticeable on the 2013... Sure it adds some straight line stability, but what you notice most is the tip in effect. Takes a bit more input to initiate a turn but once it starts tipping it continues to follow itself quickly. Like a spinning shopping trolley! I think the short nimble 2011/10 might be too sensitive to such a change.
I believe the 46mm OC Zokes used an even smaller triple clamp than the 48mm Sachs/PFP Zoke. I'm sure I recall reading threads on people considering milling them out.
My guess is that your mate has tried to measure the ID of the clamp with the fork out and bolts backed off. Could see how that would get a few mm variance. I threw a set of calipers straight onto the fork tube... and can double check those measurements again for you if required (although my KYBs have just moved on, I have a new set on the new bike).
Old 10-08-2018, 07:40 PM
(F5)'s Avatar
Roger that. He's now chasing some 06 yzf450 which look from your list to be 35mm lugs. Throwing in the wheel too which is only any good if the disc is OK. But with 250 yz disc and 35 offset the GG brake caliper may be seated a bit rearward. I think.
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Old 01-29-2020, 05:21 PM
Brian's Avatar
Brian Brian is offline
I have an 06 and I'm trying to reason my way through the switch from 45 Zokes to KYB.
Are the stock lower clamps sized such that the YZ KYB forks fit? I got this impression some how. Could you use a YZ upper triple clamp and keep the Gas Gas stock clamp for the lower?
2006 Gas Gas EC250
2011 Husaberg FE390
2013 ec250r Jakobi Enduro Product Reviews 163 02-21-2016 03:52 AM
2013 EC250R - 65Hr Report/Review Jakobi Enduro Product Reviews 111 03-07-2015 07:33 PM
2013 ec250r Jakobi Enduro Intake/Carburetion - 2 stroke 2 04-17-2014 08:08 PM
2011 Gas Gas EC250R EricW835 Used Bikes 3 10-20-2013 10:58 AM
