Old 06-04-2012, 03:21 AM
swazi_matt swazi_matt is online now
Originally Posted by Simmo737 View Post
Matt, I'm pretty sure your low speed rebound stack should be 40mm as well, not 44.
yep a few typo's there, low rebound is 40
I have the new stack from racetech and will put it up in a few minutes
2003 txt250 Pro
2013 Ossa 280i
Old 06-04-2012, 04:21 AM
Ok here is the latest stack:
so prize (of pride!) goes to webmaster for being the closes, anyone care to comment on if this new stack is equivalent or will give a different ride to the original stack?
just seen another typo low speed comp should be (6).20x44
2003 txt250 Pro
2013 Ossa 280i
Old 09-18-2017, 08:15 AM
I have decided to revive this thread.
I have realized that i am currently running my shock with HS comp all the way out (and i think it could come out a bit more for the rocky riding i do)
My plan is to do some changes, but not sure if i am doing enough or too much. I basically want to revalve the comp so that I will have similar HS comp that i have now but will be in the middle of the clickers
thoughts were to change the LS stack to5 and HS stack replace the first 3 HS shims with .20 shims like so:
existing New
(6).20x44 (5).20x44
.15x32 .15x32
.25x44 .20x44
.25x42 .20x42
.25x40 .20x40
.25x38 .25x38
.25x36 .25x36
.25x34 .25x34
.25x32 .25x32
.25x30 .25x30
.25x28 .25x28
.25x26 .25x26
.25x24 .25x24
.25x22 .25x22
.25x20 .25x20
Any comments?
(PS i am too lazy to keep opening up the shock and changing things so only want to do this once, but a bit worried that dropping one of the LS shims may be too much)
2003 txt250 Pro
2013 Ossa 280i
Suspension gurus please help stemplin Enduro Suspension 10 12-09-2011 02:33 PM
ECU gurus??? BigChina Enduro Engine 4 stroke (including EFI & Exhaust) 2 05-20-2011 11:40 AM
Need some help from the jetting gurus MattR Enduro Intake/Carburetion - 2 stroke 7 01-29-2008 01:55 PM
