Old 07-25-2009, 05:49 AM
stay_upright's Avatar
stay_upright stay_upright is offline
looked up the information in the manual and now I'm more confused, the old spring was shorter but the only shorter spring in the table is a 3.8n/mm which is not it - wire diameter is wrong. The 4.5 or 4.8 should be the same length as the 4.2....
Maybe it's a KTM spring or something?
spring rate - code - free length - wire diameter
3,8 5141144 435 mm 4,5 mm -
4 5141145 470 mm 4,8 mm -
4,2 5141146 460 mm 4,8 mm -
4,5 5141147 460 mm 4,8 mm -
4,8 5141148 475 mm 5 mm -
5 5141149 470 mm 5 mm -
4 / 4,4 5141150 470 mm 4,8 mm -
4,2 / 4,6 5141151 460 mm 4,8 mm
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 07-25-2009, 06:25 AM
OK, measured the old springs and they were 460mm long so the springs I got from Marzocchi are too long. (according to the fork PDF manual anyway)
That would mean the springs I had originally were 0.45's.
I've emailed Marzocchi to find out what's going on - my guess is the wrong springs were inside the box.
'05 Gas Gas 300
'99 KTM 200
Short 2010 250 Six Day review Skidad Ride Reports 3 03-05-2010 10:42 PM
jetting for short body PWK..... haugergaard Enduro Intake/Carburetion - 2 stroke 5 02-28-2010 12:31 PM
shift under load fullthrottle Enduro Engine - 2 stroke 4 09-25-2008 09:38 PM
External Pre-Load Ajusters for 07 Marzocchi 45's? stvbird Enduro Suspension 0 01-08-2008 10:39 AM
Not shifting while under load???? zero_chances Enduro Engine - 2 stroke 4 02-16-2007 07:40 AM
