Old 08-02-2009, 05:10 PM
GasGasser GasGasser is offline
Well I set the race sag to 105 mm before we went to the track. At first the bike was truly horrible it just bounced around the whole time. After an our of experimenting I got a setup that was rideable.
Don't remember the clicker settings exactly but they would be somewhere around this range:
Fork: Compression: 24 clicks from full soft. (the right leg adjuster was jammed with mud so I could not adjust this any harder nor count the clicks the normal way)
Rebound: 14 clicks out.
Damper: Compression 18 clicks out.
Rebound: 21 clicks out.
This way the bike felt pretty good, only the forks bottomed out frequently. They did use all the stroke. Hard to tell if the rear end was bottoming out. Gotta try some stiffer springs, maybe a set of .44's. Do I need to buy a stiffer rear spring aswell if I get stiffer fork springs?
This was on a MX track, haven't trailridden these settings yet.
Suspension Database...Could you please add your setup? wence Enduro Suspension 6 05-21-2009 05:38 AM
Desert Setup PEB General Discussions & Announcements 6 03-24-2008 06:13 PM
450 Timing setup Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 3 11-04-2007 03:24 PM
Need help with EC 300 setup Texas Gasser Enduro Suspension 4 05-24-2007 06:21 AM
New "digital" motocross magazine MattR General Discussions & Announcements 5 01-10-2007 08:50 PM
