#11
JH, are you in TX? I thought G shipped that bike to BFE?
Rob Granger / Katy, TX EC300 Breaking more things by 8:00AM than most people break all day. |
#13
no bfe.... well some people call amarillo that... but yes it is still in tx..
broken down over 60 slow rider.. |
#14
I'm also 5' 6" and put the lowering link on my '03 250. I lower all my bikes too. It instantely builds confidence. I also have a friend who uses his legs to paddle up extreme stuff. People who don't have a height issue don't seem to realize the challenges we occasionally face if not able to put a foot down.
Glen is right about shortening the spring height though. I did this to my xr400 and it rides and handles really well. My GG250 blows thru the rear suspension too quickly and it's noticeable. I either need to get a stiffer rear spring or lower the front a bit to make it better, or the best thing would be to take it to the suspension guy who did my xr. I used to cut my seat foam down, which worked really well until eventually it was too hard on my knees when going from sitting to standing. Just thought I'd chime in on a fellow short guy.
'14 Beta 300rr '05 GG DE300 '03 GG EC250 '01 XR440 '09 FZ1 |
#15
I'm 5'9" and get along well with the stock height, a big reason I always liked GGs so much. A lot of it also has to do with the overall action of the suspension, and how the travel is used. If you have too soft springs and jack the preload up to compensate its just as bad as too stiff a spring. In the slow tech stuff is where the height is an issue and you want the bike to use the right amount of travel without blowing through like it tends to do with the longer pull rods. Get the right springs, use minimal preload, and lower properly if necessary. Its easily reversable if all your doing is an inch, just simple spacers on the fork damper rods and shock shaft to limit top out length, and adjust preload spacers to compensate. This is the right way to do it if your going to keep the bike for awhile and want to enjoy it. My 12 yr old son is now 5'6" with size 11 feet. He will be at least 6'2" they tell me. What he lacks in skill he can make up for with his legs, paddling his 85 up hills when it ran out of juice. I'm envious.
Lowering links | widebear | Enduro Suspension | 10 | 01-01-2011 11:29 AM |
lowering bike | Silver | Enduro Suspension | 6 | 03-16-2010 10:35 AM |
Lowering Pegs | Dingo | Enduro Chassis & Body | 3 | 01-14-2009 10:25 AM |
