Old 04-29-2018, 06:31 PM
rvktm rvktm is offline
also italian husqvarna used 48 cc what forks are the swm s using also ask on the usa gg f book page richard willson
Old 04-29-2018, 10:41 PM
Not the same fork at all.
The typical inner and outer bushings for the 48mm Zoke can be found in the correct sizes quite easily. The bushing for the ICS piston doesn't really have any cross overs and given that they were a fork that were used on the Gassers and Betas for a few years (with both brands now using other brands; KYB and Sachs), they could be hard to come by.
Old 04-30-2018, 01:29 AM
bikesparky bikesparky is offline
Originally Posted by rvangeel View Post
I need the bushings for the inner cartridge not the normal fork tube. The previous owner broke the fork bleeder and continued to ride which allowed dirt and moisture into the inner cartridge.
Can you measure (in mm) the sizes? I have my crap Sachs CC forks of a Beta to bits and the piston looks very similar. If the sizes are the same you can get the bushings from a Beta dealer. PM me I'll get my callipers out in the mean time.
Old 04-30-2018, 06:24 AM
rvangeel rvangeel is offline
Here are some pics
Old 04-30-2018, 06:27 AM
Default Need to find Inner cartridge bushings-48mm marzocchi’s
These are the 2nd set of bushings(35151) that I ordered. The 36mm (36151) bushings were way to loose. I wonder if they bushings are getting compressed to the point that the end gap is closing.
Old 04-30-2018, 08:03 AM
Anders's Avatar
Anders Anders is offline
I have asked my local dealer but have not had much luck. He said he would look into it but have not heard anything back.
How would you recommend removing material from the inside? There is a small end gap already.
What I would do (as I have a lathe):
make a holder for the bushing. (a cylinder of slightly lower ID than the bush OD), puth the holder in the lathe and the bushing in the holder. As you want to remove only a slight amount, use e.g. 320 paper and lightly remove some material.
Place the bushing on the piston, measure O/D.
Repeat as needed.
I haven't tried to do it, but that would be my approach.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 04-30-2018, 11:06 AM
I do have access to a lathe. I can give it a try. Thanks
Old 05-01-2018, 01:17 PM
iv just asked on gg riders fb for you . bit of a long shot what about there mountain bike forks id be surprised if marzocchi had them made specially
Old 05-01-2018, 01:33 PM
as i expected richard wilson usa has a set also zipty racing n america has them rw also has softer ics springs
Old 05-01-2018, 05:05 PM
I pm'd you with the sizes of the Beta Sachs CC cartridge bushes. I think they might fit. Only thing is that you might have to adjust the end gap a bit.
PFP adjuster on 48mm Marzocchi’s rvangeel Enduro Suspension 2 03-18-2018 03:26 AM
Marzocchi 48 Cartridge Problem fixmare Enduro Suspension 30 09-11-2017 05:38 AM
Fork Oil Volume for 2013 Shiver 48mm Closed Cartridge scov Enduro Suspension 3 04-21-2013 02:04 AM
Sachs 48mm Bushings Jakobi Enduro Suspension 9 06-19-2012 07:18 PM
