#11
1) Bailey wants the same oil and knows its orange/honey coloured 2) Nutty Prof said he uses GRO in forks he works on, which is orange coloured (read on a post where they accidently put Silkolene coolant in a fork -- The green/blue coloured) I've been using GRO Synth 7 and their 10W-40, premix and trans fluid respectively. The premix smokes a bit until the bike is up to temp but runs very clean. No spooge. Light oily ring around tip of exhaust. Nice coating on the crank when I did my first pull down. Bit of carbon build up on powervalve. Not spoogy at all. The trans fluid I'm a bit so so about. Theres definately some drag, bit notchy when cold, and somtimes a bit tricky finding neutral. I guess they do a good job for what they cost. I'll probably go Amzoil Dominator once I'm out of Warranty period. I've been using GRO as thats the warranty terms stipulated by the dealer here. |
#12
Great! In the process of subtracting some oil from my Sach's fork, I noticed that the oil was the color of fresh motor oil, a light honey color.
Jakobi, maybe the down under bikes got different fork oil from the factory if yours was a blue-green? Belray is that color. The Belray oil in my old WP forks on my KTM acted very harsh, lots of stiction. If I sat on the bike, the forks would not move unless I pushed on the front end. I will look more into the GRO oil and if I can confirm for sure that it is the Sachs factory fill, I will use it.
'10 EC300 -- very happy |
#13
Nice on Bailey. Let me know how you go if you give it a try. I'm pretty happy with the Silkolene RFS that I have in them now.. Also blue/green..
#14
If this is what Sachs uses for the 5w factor fill:
http://globalracingoil.com.au/motorc...5w-10w-15w-20w Then I would get the 5wt with the viscocity of 21 in another oil brand that I can actually buy here in the US.
ec300 2000 model user manual | cjcj121 | Enduro Other... | 4 | 10-09-2010 12:54 AM |
Chain Guide? | Boomhauer | Enduro Chassis & Body | 6 | 06-16-2009 09:29 PM |
chain guide set ups | skid jackson | General Discussions & Announcements | 10 | 07-31-2008 05:29 AM |
