Old 04-21-2008, 11:49 AM
PEB PEB is offline
Thanks again for the replies boys, I love this site! My plan is to go ride the bike on Tuesday ( I try to ride every year on earth day) and then open the forks up for another bleed session and to set the oil level. After looking at lots of info on the net including the Ohlins manual I feel like a tool for paying someone to change my fork seals. I have tackled far bigger wrenching projects than fork seals, live and learn I guess.
Paul B
Old 04-21-2008, 01:58 PM
Kent A Kent A is offline
Öhlins forks do not need to bled at all if they are assembled correctly! The rebound valve assembly and so called "cylinder tube" has to be installed first. This allows you to fill enough oil to cover the cylinder tube completely. If you then carefully install the rebound valve assembly no air will be trapped in the forks.
To do this you will need the one of the special tools from Öhlins (1797-01 or 1797-06 depending on which forks you have). This is the only "required" tool for servicing Öhlins forks.
Kent
Old 04-22-2008, 08:41 AM
GMP's Avatar
GMP GMP is offline
Well that explains it, thanks Kent. If I had a bike with the forks longer than I had the Cannondale I'm sure I'd aquire the tools and learn to work on them.
Old 04-22-2008, 09:26 AM
Loosenut's Avatar
Loosenut Loosenut is offline
If your going to replace a base valve, let me know. I have a set in my garage. I opted to put in the optional high and low speen compression base valves available from Ohlins. They work incredibly well.
Mike Baxter
2005 GasGas EC300 (Ohlins front and rear)
2007 Yamaha FZ1
2003 Pampera 280(hers)
Old 04-22-2008, 03:33 PM
KTMLew KTMLew is offline
As Glen mentioned, if you can remove the base-valves and fill the cartridge through the bottom, it's no big deal...
Old 04-23-2009, 07:22 PM
jaysktms's Avatar
jaysktms jaysktms is offline
GMP, your way work great!! Just did two sets of Ohlins that way.
Thanks.
13 GasGas 300XC, CLake and now Rekluse
17 Beta 430 RRS, Clake
19 Vertigo 300
03 H-D Nightrain
www.newoodsriders.com
You Can't Out Run Death Forever
But You Can Make the BASTARD Work For It!
Enjoy Life, Have Fun and Play Hard
Bleeding Rear Brakes GMP Enduro Chassis & Body 6 11-16-2009 09:00 PM
HELP! - bleeding hydraulic clutch SpeedyManiac Enduro Engine - 2 stroke 6 10-10-2008 07:12 AM
Ohlins 46mm valving for use with spiked tire Leon_gasgas Enduro Suspension 1 03-27-2007 05:16 AM
