Old 09-01-2012, 01:26 PM
Koko Koko is offline
How do I tell if I have a reculartor/rectifier? My bike is an EC 250 and it had a headlight at one time.
2005 GasGas EC250
2012 Kawasaki Brute Force 750 w/ EPS
Old 09-01-2012, 03:24 PM
pscook's Avatar
pscook pscook is offline
The regulator has three wires, one to ground and two to yellow (I think, at least one is yellow). Reg/rec has more wires, I think four and is larger. The little regulator is tucked in the frame gap at the steering head, under the front of the fuel tank. If you have a fancy voltmeter you can test for AC or DC on the output. AC is regulator, DC is regulator/rectifier. In your second pic down, there is a yellow wire sheathed in black. I believe that is your hot to or from the regulator. I don't think you would have a DC rectifier if you don't have tail and turn lights, but I could be wrong.
The violet connects the front lights to the back lights, it has no power until you hook it up to power through the switch. It's confusing at first, but very simple once you figure it out, sorry I can't explain it very well. Grab a soda or a cup of coffee and stare at the wiring diagram for a bit. No beer, because you need (at least I did) your faculties when sorting it out. But, here's my interpretation- The yellow is hot to the switch. Violet is switched power out of the switch (provides juice to front and rear light systems). The white supplies switched power to the brake light from the brake switch, brake switch needs power from the yellow or violet wire, your choice. That should sort out your wires.
In a nutshell, yellow is always hot, and purple is hot when you connect it to yellow with the headlamp switch. White is hot when you connect it to hot through the brake switch. Clear as mud?
Here's a reg/rec-
http://www.trailtech.net/7003-0022.html
Here's a regulator only-
http://www.trailtech.net/7003-AC01.html
Phil
(New bike pending...)
Old 09-01-2012, 05:32 PM
Thanks Phil. I will take your advice and stare at that wiring diagram. According to Eff, I have a rectifer, if you look at the second picture I posted in my first post.
2005 GasGas EC250
Old 09-04-2012, 08:29 AM
Coming back to this picture...there's 4 headlight wires...can one set be wired into the DRL light? then the other two wired to work with a HI, LO and off switch or is one set the hi beam and one set the low beam?
2005 GasGas EC250
Old 09-05-2012, 10:34 PM
Upon closer inspection...I do not have two yellows and two violets. I have one yellow...which to my understanding is the hot. Another Yellow/Green which I believe is a ground...and two Violets.
Does that make more sense to anyone?
2005 GasGas EC250
EC-400 FSE - Identifying Fuses lukemillar Enduro Electrical & Wiring 4 07-08-2013 03:17 PM
Too many wires 03 EC125 fire1998 Enduro Electrical & Wiring 3 06-10-2012 08:47 PM
Which wires for horn?? solstice Enduro Electrical & Wiring 0 04-09-2012 08:23 AM
Help with Identifying Particular Skid / Bash Plate qgstrydom General Discussions & Announcements 2 07-26-2011 07:14 AM
2 unplugged wires ec 250 dareuk Enduro Electrical & Wiring 1 03-22-2010 03:59 AM
