#11
You can add more preload to bring the static down to 35mm, and then see where the race sag sits. Ideally, a heavier spring with less preload will still allow it to sag a little less in both departments.
Stock Spring Rate in '11 Ohlins Shock? | bputt | Enduro Suspension | 2 | 01-13-2011 01:47 PM |
Where to find a sachs shock spring? | bergerhag | Enduro Suspension | 3 | 06-16-2010 01:25 PM |
Shock spring rate.?? | wence | Enduro Suspension | 4 | 04-16-2009 02:41 PM |
Spring rate on Ohlins shock | KicksonR66 | Enduro Suspension | 11 | 12-21-2007 02:58 PM |
??SPRING rate | GAKLX | Enduro Suspension | 4 | 07-12-2007 07:10 AM |
